Home > Technical (L322) > Rev counter
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Rev counter
Any one had this when cold the rev counter seems to jump a little does not affect the drive it just seems to bounce a little
Cheers Thumbs Up
Post #485454 8th Aug 2018 11:02am
ptaroni
Does it jump up like 200 odd rpm at a time? Like steps almost but doesnt actually feel like it
Post #485583 9th Aug 2018 9:55pm
Henda
Yes it seems to don't know wether it's my foot or the car Thumbs Up
Post #485718 11th Aug 2018 4:52pm
Mikey
Fluctuating a few hundred rpm’s when under load?
Post #485722 11th Aug 2018 5:17pm
Henda
No mate just when going steady at about 1500 rpm Thumbs Up
Post #485724 11th Aug 2018 5:28pm
ptaroni
Did a gearbox oil and filter change this morning at work, used some mpm m1375.4 oil , drained and filled then ran with that twice then filled with ravenol 6hp ran then drained then filled again, reset adaptions and now my issues have completely gone!
It is so much smoother! The sump pan was metal and didnt look very old so maybe it has been changed with the wrong oil before?
Post #485737 11th Aug 2018 6:52pm
Henda
Mmmm food for thought it's just had a gearbox oil and filter change , maybe worth doing it again a few £££s now is better than £1000s later Thumbs Up
Post #485739 11th Aug 2018 7:27pm
ptaroni
What oil did they use?
Post #485740 11th Aug 2018 7:42pm
Henda
Not sure it's in the sevice book as oil and filter change and the filter is new
What's the best oil to use ? Thumbs Up
Post #485746 11th Aug 2018 8:28pm
For TDV8
http://www.fullfatrr.com/forum/topic47773.html .
Post #485756 11th Aug 2018 8:44pm
Henda
So it's 71141 and a plastic or metal filter ? Thumbs Up
Post #485762 11th Aug 2018 9:10pm
For the filter, a Landrover one will be plastic, there are others with a metal pan and separate filter, designed to overcome subframe obstruction on Spurts and Discos.
Advanced Factors
LRParts .
Post #485773 12th Aug 2018 12:57am
ZF lifeguard 6 fluid is the way to go, though merle and get an oem filter from filtrans which is plastic. Don't try to use any other spec of fluid as it will not be happy.
DO NOT PUT LT71141 in your 6 speed transmission......!!!!! NOOOOOOO There is nothing that can't be fixed with a hammer😜😜
Post #485803 12th Aug 2018 2:51pm
Henda
Will do
Cheers Thumbs Up
Post #485813 12th Aug 2018 5:04pm
Henda
I ve been watching this rev fluctuations and they only happen when the gearbox is cold once up to temperature everything is as normal so will leave the oil change until the summer Thumbs Up
Post #494588 4th Nov 2018 1:58pm
