![]() | Home > General > Silica gel packs in rear boot compartment?? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3793 ![]() ![]() |
£1 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35736 ![]() ![]() |
apparently they are in the 99p shop as well..
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
118.... |
119..... |
To be fair. Probably won't be worth the wait anyway!!
it appears that i mis represented the truth and we do have a pound shop which i frequented, but sadly couldn't find any silica bags...
nick, i have dug out a few 1kg bag of crystals from my machines, since you are haveing a big prob with mosture pm me your address and i will send you one, if you weigh it when its dry you can tell how much water it has absorbed ... V8 facelift Range Rover Autobiography 22" wheels.
Done, thanks Daveo, top man. |
sportin Member Since: 12 Mar 2011 Location: USA Posts: 26 ![]() ![]() ![]() |
I agree that leaving the cc on helps lower the humidity.....i don't think it helps much when the boot area is closed up.the forced air vents only have a small spongy seal protecting the electrics area. I have found that the silica gel packs do help.get the ones that change color when they are fully absorbed. You can put them in the oven to dry them out to be reused. A small price for a little extra piece of mind. As always just my humble opinion 2006 RR 4.4 HSE
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 ![]() ![]() |
Might have a look in our local 89p shop.. yes .. 89p !! Think i'll need to check i've had all my jabs before i go in there though. |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
lol them shops do get you a bit like that ....im always the fella standing outside waiting for the other half to come out "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
I have found that the "sat nav being slow to turn on" is related purely to the battery voltage rather than the humidity levels - after a 1400 mile trip across Europe, the sat nav is there in seconds but after a few weeks of 10 miles commutes, it takes up to 10-15s to appear. Try charging your battery rather than buying silica ! |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I would argue that one Dan. I notice a difference in MPG if mine is left off. According to the "range" in the OBC anyway. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
