Home > In Car Electronics (L322) > AUX-level fix!
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
AUX-level fix!
Hi all,
I hope this may be helpful for others who have decided that the pathetic amplification level of the rear Aux input in their L322 is just too annoying to live with.
I purchased one of these: https://www.ebay.co.uk/itm/NE5532-Stereo-A...3d5c87b3ed
and installed it in line with the aux input. It works like a charm and raises the level to where my phone / ipod matches the cd-player without twirling of the volume knob. I've got it temporary now, but plan to install it permanently somewhere behind the rear heater controls. It can we wired directly to the rear cig-lighter, since this is switched by the ignition. I will then unsolder the input jack and wire it directly to the amp input and wire the cable I remove from the jack to the output of the amp. The end will be a completely hidden and permanent fix to this very annoying problem.
Hope this helps!
Henrik
Post #483627 17th Jul 2018 11:52am
looks well made..good find sir Thumbs Up ... - .- -.
Post #483630 17th Jul 2018 12:14pm
nino_nino
Henrik07, do take some pictures so we can follow Thumbs Up
Post #483654 17th Jul 2018 4:31pm
Henrik07
I will, when I get around to the permanent install. At the moment, it's all hanging off the cig lighter.
Post #483670 17th Jul 2018 8:55pm
paulgo
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
This sounds like something I could certainly do with! Have you had a chance to take some pics 🖒 2007 Range Rover Vogue 3.6 TDV8
Post #485495 8th Aug 2018 10:21pm
paulgo
I also meant to ask where you've got this placed i.e in the loom before the aux socket in which case how did you wire it in? Thanks! Very Happy 2007 Range Rover Vogue 3.6 TDV8
Post #485512 9th Aug 2018 9:57am
Henrik07
Hi,
No pictures yet - it's still just a temporary install. Basically, I've soldered a female mini jack to the input of the amp and a male jack to the output. The output goes to the aux socket and the input is now my new aux socket, into which I plug my ipod, phone or Ugreen BT unit.
I will take pics when I go permanent.
Post #485513 9th Aug 2018 10:16am
paulgo
Ah - got you, thanks. Did you just unsolder and replace the phono sockets on the board? I think I'll definitely give this as go Thumbs Up 2007 Range Rover Vogue 3.6 TDV8
Post #485520 9th Aug 2018 11:05am
Henrik07
No phono sockets on the board. It's a simple 3-pin in and 3-pin out. I was lucky enough to have suitable connectors on hand, but if you don't, just solder your wires to the pins directly. R, L and gnd is printed on the board, so it's pretty foolproof. For a temporary install, just get a mini jack extension cable and snip it in half, soldering each end to the amp board and a ciggie-plug to the power input.
Post #485558 9th Aug 2018 4:53pm
paulgo
Sorry - I think I veered off somewhere and have been thinking of a slightly different board - but looking at the one you actually used I get what you mean!. cheers 2007 Range Rover Vogue 3.6 TDV8
Post #485560 9th Aug 2018 6:41pm
dirtymonkey38
Did this get finished? trying to get my head around what plugs in where....I'm planning on wiring in an amazon input device into the rear aux port (probably soldered to the back of the panel). does this board need wiring to the cars amplifier or does the board amplify? 2011 RR Autobiography 4.4 TDV8
Post #518965 18th Jun 2019 10:34pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
What about this one already to go on?
https://www.ebay.co.uk/itm/Portable-Audio-...SwrxFc4qJ8 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #518967 18th Jun 2019 10:51pm
Great find sir Thumbs Up
Post #518969 19th Jun 2019 12:15am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
https://www.ebay.co.uk/itm/RED-Coiled-3-5m...SwM~taX2Kw
And you will need one of these.
Post #518977 19th Jun 2019 9:14am
Henrik07
The board amplifies. It raises the level of the output of your mobile device to where it better matches the sensitivity of the aux input. I have yet to make the input permanent, looking at bluetooth module to go with it.
Henrik
Post #524270 9th Aug 2019 4:20pm
