Home > Technical (L322) > Oil leak 4.4tdv8
Herald
England 2012 Range Rover Westminster TDV8 Santorini Black
Oil leak 4.4tdv8
My 2012 Westminster is currently with a main Land Rover dealer, I have confidence in their work and the car is still just under LR Approved Used warranty. They have spotted an oil leak and want to remove the front diff to find it. As this isn’t yet a warranty claim they want my authority as normal to bear the cost in the event of no warrantable fault being found. It’s already had a turbo back at the start of the year due to an oil leak and two years ago had the mod for oil feed somewhere after limp mode appeared.
The question is what could be above the diff that can’t be seen, and could anything leaking oil of reasonable quantities be considered as not a warranty job? I don’t really want to pay that rate to remove the diff and discover I really am paying!
Post #485572 9th Aug 2018 8:47pm
Herald
Well they assured me that every oil leak they could think of would be covered so today the diff was removed and it has a ma)or oil leak from the rear of the engine. Engine needs to come out to sort it and that is great news as it is another job sorted whilst it has warranty. For interest, it is 77000 miles so oil leaks appear to be a bit of a common problem on this engine as I’m on my third one so far.
Post #486000 13th Aug 2018 8:14pm
GGDR
Wow that seems hard-core. Can you let us know which seal it is when you know.
. Cheers, Greg
Post #486003 13th Aug 2018 8:28pm
mjdronfield
I had one of those....
http://www.fullfatrr.com/forum/topic35830.html?highlight=oil+leak 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #486008 13th Aug 2018 9:14pm
Herald
They’ve sent me a list of parts it needs and the fault is down as sump oil pan gasket.
Post #486102 14th Aug 2018 6:19pm
