Home > General > Here's an oddball.
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Here's an oddball.
Just filled up at Tesco (10p off per litre when you spend £60 in store) and when I started the engine the front wipers went to straight up position and parked. Nothing I did with the stalk would make the wipers do anything. Rear wiper was running as normal.
I moved off the pump and to a parking space. It was Censored down. I found the power steering felt heavy on the short trip from pump to parking space. Sat in the parking space for 30 seconds and the wipers started again so I pulled off and the power steering was back to normal.
Everything fine for the 12 mile trip home. 1 stop and start cycle once I got home and everything normal.
Is this likely battery related gremlins or something more sinister? 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #485546 9th Aug 2018 2:24pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Cant answer question, however when I taught part time at the college in St. Albans few years ago I was driving a rover 214 SEI and every time I parked in their staff car park my radio wouldn't work and the central locking always malfunctioned.
I had to use the key to manually lock / unlock it. That was the only place I had problems with it in all the years of ownership. All I could think was there was a high voltage cable near the surface radiating some sort of electrical radiation. I know they should be screened but maybe there was a fault.
Also, areas that use a smart barrier (bar lifts as you approach) have a circle of live wire (approx 20ft in dia near the surface.
The idea is, the windings generate a weak magnetic field that as the car body enters the field it interrupts the field and a sensor triggers the barrier to lift.
Just a thought Question
Post #485588 9th Aug 2018 10:34pm
p38arover
Australia
Re: Here's an oddball.
What these "wipers" used for? Whistle
We haven't had rain in months and none is forecast for at least another two. Big Cry I wish it would rain, much of the state is in drought. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #485590 9th Aug 2018 11:21pm
