![]() | Home > Technical (L322) > Eas abs reset tool |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
Hi anyone used this tool seems handy for £70\80 |
Ok sory don't know what happened there .Is icar soft ok .looks better have you tried this ? Eas reset tool is on eBay plug in to socket and light comes on info on dash resets eas and abs faults looks similar to iid tool |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
If you don't have a full diagnostic tool for your FFRR, you should get one!
Hi Joe what about Carsoft any good? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I have heard good things about the icarsoft as price is good but there are different models, i the 930 might be the one but make sure it will read and clear faults , I wouldn’t waste your money on one that only does EAS and ABS, they are only two of the faults of the many you will experience
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 541 ![]() ![]() ![]() |
I have iCarsoft i930 and IID BT so if you want any info just ask. The iCarsoft is quite capable but awkward to use. Can certainly read and clear faults. 2016 Skoda Octavia VRS Estate
Cheers mate will keep you in mind |
Ok guys bought Carsoft today can't wait 👍 |
Cool, I’d be interested to see how you get on with it. |
Will let you know .I have also ordered 6mm compressor pipe repair kit so will.have to do a reset with it when it comes .Will be a good test .I also have a td5 disco with window probs mabe find out what's wrong with it as well.fingers crossed. |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I looked at the icarsoft before buying an IID tool.
How much is the GAP and icarsoft ? |
Gap £400+ carsoft £136app |
That's ok by me clearing faults and diagnosis is fine anything else is probably best left to experts . |
