![]() | Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2759 ![]() ![]() |
I have already received a response from Patrick where he states that Gap have provided live values for all live values implemented by LR for this engine. I have also been advised that Autologic also only shows the 4 exhaust pipe temperature sensors. I wonder if LR forgot to include the EGR temperature sensors considering that the version of the wiring schematic that I obtained from Topix a while ago mislabelled the EGR temperature sensors as a 2nd set of pre and post catalytic converted temperature sensors, corrected by a correction document. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Ah I see. But if there is a sensor on the car sitting out a value there must be a way of seeing it surely?
Sensors etc are only accessible via the OBDII port if the ecu software is programmed to provide the specific data upon request.
Hi Nino, apologies fior he the delay, here it is:
Tackling this job today, but as Craig has reported, it's definitely a cow (level 9).
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
None of these jobs are ever easy are they |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I found couple pictures that show the position of the sensor well.:
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
Greg,
Hi guys, well spent the last couple of hours since last post trying, dropping a socket somewhere difficult, retrieving it, putting everything back and retreating, having lost the battle.
Nino, I think that is the other EGR sensor? The one on the EGR maybe?
It's all Ford's fault:
Now you know why i don't entertain doing them sir! FYI JLR main agents book time for this job is 0.8hrs and the probe is £40-£60ish so £130-£180 all done... I cannot compete with that price so send all of mine to our local Main Dealers... ![]() |
