Home > Maintenance & Mods (L322) > L322 4.4TDV8 Front Brake Pad Replacement
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
Is it straight forward job to replace the front pads on a 2012MY 4.4TDV8? I've replaced plenty of other models, including range Rovers and Land Rovers in the past but not the 6 pot callipers before.
Other than the overflowing brake fluid reservoir when pushing the pistons back in, is there any tricky element involved?
Many thanks.
Post #486218 15th Aug 2018 8:58pm
looks easy'ish,
http://www.fullfatrr.com/forum/post197471.html#197471 ... - .- -.
Post #486219 15th Aug 2018 9:01pm
SinbadRose
If just doing the pads, super easy. I followed wiki and will be doing my disc and pads all round when the rain stops long enough on a weekend.
Post #486224 15th Aug 2018 9:51pm
cass
As others have said it’s not difficult provided the retaining pins aren’t seized.
I would suggest planning on putting new pins in.
Post #486250 16th Aug 2018 7:26am
stoutgoose
Many thanks all.
Post #486279 16th Aug 2018 1:20pm
wildeone2
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Takes less than a hour just need a punch to get pins out mine slid out easily
Post #486535 19th Aug 2018 10:08am
nino_nino
when I do mine I do this:
put pins in a drill and polish using 400 grit and polishing compound, after that apply nano coating and some dry PTFE
no more sticky pins Thumbs Up
Nino,
Post #486536 19th Aug 2018 10:28am
stoutgoose
Thanks for all of your replies. The job is very straight forward, but made a great deal easier when starting forewarned about the pins.
The pads had travelled 52000 miles and were pretty thin, however the warning light had not illuminated. The sensor appears to be in good shape.
Post #486570 19th Aug 2018 4:20pm
Baltic Blue
It is 18months since my front discs and pads were changed.
Today I intended to replace the pads, but found them to be still only half worn.
I did however remove all the pins and centre bolt to clean them and apply a smear of grease.
The bottom pins on both sides were pretty well stuck and took a bit of persuasion to drift out.
I am convinced that if the pins are left in situ for the full life of the pads they will be virtually seized in.
It only took me half an hour to do both sides and I recommend not leaving them in-situ any longer than 18 months.
Post #486686 20th Aug 2018 9:50pm
