![]() | Home > Technical (L322) > Trans fail safe mode |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
Is your transfer box working correctly? That’s how my issues started on my last car.
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
Do you get any other issues at the same time like suspension inactive?
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
When you’re in failsafe mode, does Reverse still work fine? Does the transmission operation return to normal once the fluid has cooled down but then go back into failsafe around 15 minutes after starting from cold? Does your transmission lock in 5th gear rather than 4th gear when failsafe is engaged, and also engage drive with a bit of a thump when selecting Drive from Neutral?
Wickford90 Member Since: 03 Jan 2018 Location: Esex Posts: 13 ![]() ![]() ![]() |
Doesnt seem to be any other issues, suspension ok but will check tomorrow , no noise from drive to neutral, how would I check if it's stuck in 4th or 5th. Goes into fail safe after a couple of miles, will be normal again after a few hours parked.
Reverse is fine, suspension goes up and down maybe a little slow and i can hear pump working
I appreciate that, because the torque converter lock-up clutch is automatically disengaged in failsafe mode, it can be hard to distinguish between 4th and 5th gears just from the engine revs.
Thanks will take it down the dual carriageway tomorrow and determine what is what. If the problem is as you suspect what would need to be done and ballpark cost, ( I appretiate cost is dependant on who does it)
If it’s the axial bearing/O-ring issue, and you’re handy with a set of spanners, then potentially you could repair it yourself quite cheaply, but with an element of risk. If you drop the transmission and only remove the A & B clutch assembly to replace the bearing and O-ring then the chances are that you’d get away with it with just £70 worth of parts.
Thanks, going to take it for a run and try and confirm what gear it's stuck in. |
Took it down long flat lane, at 1000rpm it hovered around 20 mph or a tad over, drove a few hundred mtrs and it was constant at that speed. |
Unfortunately, the difference between engine speeds in 4th and 5th only becomes apparent at higher vehicle speeds. So, for example, at 60mph 4th gear is equivalent to around 2500rpm and 5th gear would be 2000rpm, so the 500rpm difference should be apparent on the rev counter.
Thanks will take it out again later and check at 60mph, I guess there isn’t a sure fire way of checking. |
