![]() | Home > Technical (L322) > 2.30 amps parasitic draw? 2003 L322 TD6 |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I was going to suggest alternator as you seem to have eliminated most other possibilities. |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
I've had parasitic draws in the past on my 04 and nothing really ever showed up on any tests.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
^@ low
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
nicedayforit, the thick cable that goes from the jump post on the engine side of the of the bulk head only seems to go directly to the starter motor ,am I not seeing something? |
Is there then not another cable looping from the starter to the alternator? |
I just found out there is a hiden fuse box inside the Ebox in the engine compartment which I did not see, so will pull those fuses also.
To test for current a from jump stud to alt, I place the amp meter between the lead and the stud,, I assume i need to reconnect the negative cable back onto the batter first? I don't want to damage my multmeter . |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 ![]() ![]() ![]() |
You really need a clamp meter to check for parasitic drains. Disconnecting cables and putting a multimeter inline will often 'wake' the car up again.
MY BAD,! it's not 2.30 Amps, I misread the new meter. its 0.230 amps.
0.23 amps is still not good...
Update, I found a shorted couple of wires in the spare well, they were for my reverse camera i had installed in the bumper a while ago, the wiring had rubbed through on the body work. The pos wire seems to be live and is shorting to earth. this may be my problem. . |
