![]() | Home > Technical (L322) > Suspension woes |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
I’m losing the will to live with my suspension. I’m using the iid tool and it’s showing no faults. Yet I get air susp inactive on the dash. The suspension rises to off road mode on the front when I switch off the car and I have to use the iid tool to lower it in the “test valves” menu. Once I re-enable the EAS it creeps back up to off road height again.
| kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85
Are front level sensors working properly? -08 3.6 Vogue
As far as i know, yes. I did find a fault using iid tool suggesting the left hand one was at fault so I ordered a new one. However when I went to fit it, I noticed a break in two of the wires to the sensor. I soldered them and that fault cleared but now I’ve got this problem instead. |
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276
Assuming you rewired the sensor correctly, it's very strange that your IIDTool is reporting no faults.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Symptoms do point to a height sensor... .
Have you tried EAS calibration with IIDTool? -08 3.6 Vogue
I have tried. Not sure if I’ve done it correctly as all I could find was manual calibration. All the setttings in there were 139 and 156
I thought it went up to off road height ? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Ah yes, our old one (2002) I drove like this for quite a while before I managed to get around to fixing it. The problem in my case was the rear left height sensor lever kept popping off and I got sick of reconnecting it so just drove with the EAS in test mode and manually adjusting as necessary. Assuming it is dropping when you've disabled it by leaving it in test mode, this indicates you have slight leak, but that's a secondary problem - you need to find the cause of it becoming inactive in the first place. (Eventually I fixed the height sensor properly as I wanted my suspension working again Like I said above, check the live values - there may be a clue there. Edit: Note, that if it does indeed creep up with the EAS in test mode, it may indicate a leaking valve or valves (the main valve block is in the sill under the drivers door on yours). |
IT doesn’t creep up in test mode. It’ll stay where I leave it. It probably takes a good three weeks to drop a couple of millimetres.
| All times are GMT |
