![]() | Home > Technical (L322) > Front suspension |
| A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 159
Some weeks ago, I've replaced all the suspension control arms due to bad bushes. It where much easier to replace the complete arms than the bushes. I've tightened with the specified torque.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Believe they should be torqued when wheel is on the ground or when suspension is aligned with the road going position.
Hi Joe
HERE is a thread all about it |
| holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086
I drive up on to a couple of railway sleepers to give me the height required as some of the bolts are pretty tight and need a decent length of torque wrench |
| alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349
36mm 12pt for socket |
| All times are GMT |
