![]() | Home > Technical (L322) > Can a 07-12 S/C fit in a 1.83m car park? |
JC1098 Member Since: 27 Aug 2018 Location: Canada Posts: 5 ![]() ![]() |
Yes, another height thread.
But on the wiki, height is 1.90m or 1.87 depending on year, minus 40mm for access height still isn't enough. On top of that, I can't figure out if those numbers are with or with the GPS antenna. I could bring a measuring tape when I go try them out, but the accuracy of that isn't the best. Nor do I know how accurate the car park's limit is, but that one's easier to measure. Secondary question, can I go all the way down to the bump stops? Either a hidden lower-than-access mode, or some electronic fiddling (IID Tool? EAS Control? GraemeS -not sure I have the right user- sells adjustment chip or tool?) If yes, what's the height then? Of note, I do want full height for driving around on and off road. Not keen on a permanent lowering. |
Not a one time thing I'm afraid, it's the work car park.
If the std height is indeed 1.90m, that gets me a whole 2cm to spare. ![]() I will report back once I have everything in hand. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Even if we know we can get under the barrier, we still duck inside the car, and for every concrete beam in multi-storey levels |
ilard Member Since: 21 Oct 2012 Location: London Posts: 715 ![]() ![]() |
I would just invite one or more forum members to meet you in that car park, set up a time lapse camera, and then see what happens. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8086 ![]() ![]() ![]() |
Not too many members in Canada |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
What about investing in a Llams kit for your beast.
Ah yes! That's the one I'd heard about. Thanks for the link, that's bookmarked. And sending him a PM. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Could you dig a bit of the floor out? 2006 4.2 SC
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Change jobs is the easiest option |
Make up a frame somewhere and do a detour on your test drive |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
If you go fast enough it will go under |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
The easiest (most sensible) answer would to buy an IID tool and lower the access height then drop it to access before approaching the barrier. |
Can the IID tool set just the access height ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35799 ![]() ![]() |
from the 2006 years you correct Alistair, anyway who would want to use the iidtool to lower day in day out.... |
