Home > In Car Electronics (L322) > Rear seat electrics
Jpboost
Rear seat electrics
Hi All,
I've got a 2010 S/C AB, and have just had deployable side steps fitted.. which are fantastic, but since fitting, my rear seat electrics don't work.
I've got the electric adjustable rear seats with heating/cooling etc. And now none of it works (and it all did previously). I've checked all the fuses, and they look fine.
I know as part of the deployable step fitting you have to remove a main connector off the fuseboard and add a new cable, so I'm wondering if the garage have dislodged the power feed to the rear seats.
Any ideas? Does anyone know exactly which fuse and/or pins are related to the rear seat electrics?
I'm working on the assumption that there's no coding or anything that could need to be reset to enable the rear seat functionality?
Any help gratefully received.
Jon
Post #487257 27th Aug 2018 11:25am
GGDR
Might be an easy one, try the electric windows look out on the drivers switch panel Cheers, Greg
Post #487278 27th Aug 2018 3:18pm
Jpboost
unfortunately, I'd already tried that.
But your post made me re-check, and while I was out there, I pulled and refitted all the fuses that related to the seats, and bingo ! it now works Smile
I can't believe any of them weren't connected, as they were all tightly fitted, and there's no corrosion or anything. Ican only assume cutting and reinstating the power has reset something.
Has cheered me right up, might even give her a wash!
Cheers
Post #487297 27th Aug 2018 5:28pm
GGDR
great news! either a jiggle or some kind of reset huh?
And now you can enjoy the gadget completeness now you have your steps.
Which are literally the best gadget E V E R Thumbs Up Thumbs Up Thumbs Up
. Cheers, Greg
Post #487307 27th Aug 2018 7:00pm
rjff
Looked at an AB in Duckworths while picking up a Gap tool from Dan.
Deployable side step option £3100.00 ish Shocked Shocked
Post #487483 29th Aug 2018 9:03pm
Jpboost
I must admit, I bought them as I thought they'd look good, but in reality they are really useful. And so much better looking that the fixed steps.
Post #487530 30th Aug 2018 10:22am
rjff
Jpboost
Thinking of fitting these for Mrs rjff who has difficulty getting in/out. Would you mind telling me how much and where you got them fitted?
PM if preferred
Richard
Post #487541 30th Aug 2018 11:13am
Jpboost
Hi,
I got a local garage to fit mine. I'm near Gatwick.
Book time (on the LR instructions) is 2 hours.
I (helpfully I thought) had printed out the instructions from the wiki for the garage to have a look at ahead of the job. Unfortunately this actually was counter productive as the wiki ones, were from a slightly different model, with a different plug on the loom, which caused considerable confusion.
Using/reading the instructions that came with the steps cleared up the issue, but he lost some time on that.
So on the whole, mine took about 4 hours to fit, which is in the £250 region. I was happy enough with that.
Post #487542 30th Aug 2018 11:22am
Removing the fuses and reinstalling is the same as performing a battery reset sir...
So, what probably happened is your rear seat module went into a distressed mode (neither on nor off) and a battery reset forces all ECU's to reset... Thumbs Up
To be absolutely sure no other ECU's are effected, i would do a full battery reset when you have the spare time sir Thumbs Up
Post #487544 30th Aug 2018 11:33am
Jpboost
thanks for that craig.
I'm new to RR ownership. From what i can find, the battery reset is:
leave it unlocked for 5-10 mins or so, so everything shuts down.
disconnect the battery. (earth first)
short the battery leads.
reconnect battery. (earth last)
Is that right?
Cheers
Post #487545 30th Aug 2018 11:37am
Yes sir that is correct... Or simply leave the battery disconnected for half hour or so (soft reset) Thumbs Up
Post #487550 30th Aug 2018 12:13pm
Jpboost
perfect. cheers.
Is either (soft or hard) better? or the same effect but quicker?
Post #487564 30th Aug 2018 2:07pm
rjff
Jp
Thanks for the costs, kind of you and may get them fitted, BUT you know how independent the ladies like to be Confused
Richard
Post #487566 30th Aug 2018 2:17pm
