Home > Technical (L322) > height sensor voltages
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Can any one give me a heads up as to what the correct voltage reading should be on the height sensors on a TD6.
I have replaced both rear sensors as one arm broke when i hit a pot hole suspension works fine. In fact I was able to calibrate it the other day without any issues however occassionall the suspension turns its self off It can run for days sometimes weeks and then all of a sudden suspension inactive.
Put the inpa on it and all seems to work fine recording correct suspension height etc the only odd thing is the voltage reading from the sensors which is :-
fr 2.87
fl 2.88
rl 1.86
rr 1.04
checked wiring no damage plug seems fine not corroded pins look good. I am wondering if the sensors faulty they were after market ones.
Any thoughts would be greatly appreciated
Post #487631 31st Aug 2018 2:08pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
There's a procedure for testing them in the workshop manual which may help. See this thread : http://www.fullfatrr.com/forum/post482719.html#482719 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #487653 31st Aug 2018 5:41pm
horsedentist
cheers
Reading that I think its probably the sensor then. I have just calibrated the suspension and both fronts are showing around 2.8v which leeads me to believe that both rears should be showing a simaarl voltage to each other ie if one is at 1.86 the other should probably be the similar for the same height setting.
1.04 volts seems way low.
They were after market sensors so I will try replacing it.
Post #487683 31st Aug 2018 10:56pm
horsedentist
Update I finally got round to swapping the offside rear sensor out yesterday and that seems to have done the trick. Recalibrated the suspension to 490mm front 480 on the rear and both rear sensors now showing 2.11 volts so must have been a duff sensor. Lesson learnt don’t buy the cheap ones!
Post #489088 17th Sep 2018 12:21pm
