Home > Wheels & Tyres > Changing wheels QUICKLY
Page 1 of 3 123>
Vogue
On my L405 I have a set of 22”, I also have a set of All Terrain 285’s on another set of 20” wheels for the shooting season and of road work.
Changing wheels over was a tiny bit of a bind. However, equipped with a 3 ton trolley jack and an impact wrench I can swap over all 4 wheels in under 10 minutes - thanks to my new tool.
Seriously this is an absolute weapon and probably the best £450 I have spent ! It also absolutely eats the track bolts on a 15ton Case 360.
For those of us who need to swap wheels over with ease have a look at this:-
 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #487682 31st Aug 2018 10:47pm
Mikey
I have the previous “biggest” 1/2” impact gun they done, at 1491Nm. We no longer have air tools in the workshop, air is only used for inflating tyres now...
The only thing I have found it won’t undo is a 3.0 crank pulley bolt
Onto my 2nd one now, the first one loosing a fair chunk of torque, is away for a refurb at £85 Thumbs Up
Just looking for an excuse to upgrade to the latest one now, at just shy of 1900Nm Mr. Green
In addition, I also have the impact bit driver, which despite its size, will still undo wheel nuts Thumbs Up
Post #487695 1st Sep 2018 7:52am
My local tyre guy recons it’s the impact gun that knackers the RR wheel nuts, so always does mine by hand.
When I do my own I start/finish them by hand with a torque wrench and use my cordless drill for the bulk of the thread
(off topic but I just bought an impact bit driver as Mikey mentioned - they are awesome for screws - I did a load of floorboards and it’s sooo much faster than a cordless drill - I hadn’t realised the difference between those and a wrench before - should have bought one years ago Embarassed )
Post #487696 1st Sep 2018 7:59am
Mikey
I reckon it’s just a Censored design Whistle
Post #487698 1st Sep 2018 8:02am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Ive just sold 20 of these , latest model is a beast , theres a great advert , shows a rally car pulling for a pitstop and one of the crew puts the gun on a wheel nut and instead of undoing the wherl nut it flips the car!!!!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #487699 1st Sep 2018 8:04am
Mikey
Rolling with laughter
Post #487700 1st Sep 2018 8:10am
dolph34
That's the one Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #487701 1st Sep 2018 8:12am
wizzy guns are ok for undoing wheel nuts but you should be careful doing nuts up.....remember to use a low torque setting and to finish of with a torque wrench..
Post #487703 1st Sep 2018 8:20am
Mikey
Mine gets used for timing belts, stripping dashboards, stripping engines etc. It’s effortless. And if you opt for the M18 range, all batteries are interchangeable Thumbs Up
Post #487705 1st Sep 2018 8:28am
dolph34
I have the Milwakee radio which as well as being indestructible it also charges the batteries. The jacket is also the business in the winter and uses the 1/4 inch gun battery to power the heated jacket Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #487706 1st Sep 2018 8:41am
Mikey
I had looked at them Whistle Laughing
Post #487710 1st Sep 2018 9:06am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
They seem to have so many models - which one would make my life easier for suspension bolts?
Cheers Thumbs Up
Post #487729 1st Sep 2018 11:32am
Vogue
I’d get the same one I did the High Torque 1/2”, they also do a 3/4” with a bit more Torque but that will easily snap M16 bolts if you are not very careful 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #487741 1st Sep 2018 1:00pm
dolph34
The new model 1/2" has the same motor ( and subsequently) power of the 3/4" model. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #487764 1st Sep 2018 3:37pm
Vogue
Stan, the new models from Milwaukee have 4 settings, they link to your phone by Bluetooth and you can change the Torque Settings, speed and trigger sensitivity with the OneKey App for each of the 4 settings - it also lets you track the location of your power tools in case they get nicked, plus a load of other features.
They are absolutely brilliant as you can set a dedicated Torque up for several different uses or vehicle wheel nuts. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #487771 1st Sep 2018 5:49pm
Page 1 of 3 123>
