Home > Maintenance & Mods (L322) > Calling CAN bus gurus
j_rov
I've got a desire to make some mods to my lights, to make them operate a little like an emergency vehicle (hazard strobe, alternating headlights etc). Note, these will not be on-road use.
So my question is, can this be done with programming alone? If so, has anyone got any tips as a starting point? I know I can intercept the wiring to the lights and provide new signals, but would ideally like to add a module, perhaps to the ODB2 port which will do this as I feel shoving additional signals over the CAN bus might cause errors to be logged.
Something like this perhaps?  __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #487535 30th Aug 2018 10:46am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Sorry, only just seen this.
I have previously developed modules (hardware and software) and also CAN bus loggers for clients.
I've just checked the wiring diagrams for this area, and it is clear to see the 'Central Electronics Module' (CEM) is connected to the switches and the lights using traditional wiring. They aren't controlled using CAN messages, and it doesn't look like the CAN bus is connected to the headlights at all.
Whether you can issue a command to the CEL in order to control the lights, I have no idea.
I believe the OBD connector is directly connected to the CAN bus on the RR, so you could probably monitor the bus, but I'm not sure if that will help you. I haven't attempted to log anything off the RR, but don't see it as being an issue.
You may well find the companies that outfit cars for emergency services already have modules for this, but they will be spendy. Then again, they may well modify the wiring in order to insert their own modules between the CEM and lights.
This would certainly be the easier approach imo.
Happy to answer questions if I can help. Not sure how far you can get with simply plugging something into the OBD port though.
Cheers,
John. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #487976 4th Sep 2018 1:22pm
j_rov
Thanks, I've just dropped you a PM. Hope that's OK... __
Land Rover History:
1976 Series 3 2.25
Post #487984 4th Sep 2018 3:53pm
GGDR
John a closely related question: I'd like to introduce a repeater volume control (for volume tweaks from the rear) was wondering if that would be possible? Either CAN or just repeating the switch in parallel?
. Cheers, Greg
Post #487994 4th Sep 2018 5:20pm
John w
I will reply to your pm in a moment Wink
Greg, this will probably need to be a MOST module, not CAN bus.
Having taken the head unit apart, you could undoubtedly try to parallel up a volume control, but it would be messy as it's not a potentiometer, it's an optical encoder with an interface pcb. To make a module from scratch would be a lot of work.
I would work along the lines of using a remote and it's receiver module, or cordless headphones which have volume controls on them.
There are modules out there to interface to the MOST bus (mainly for phone and mp3 interfaces) but everything seems to be 200 up.
Send me a pm if you like, we can talk about it more. Too many toys, not enough time
Post #488018 4th Sep 2018 8:57pm
This sort of thing was/is possible with the 1st gen FFRR (BMW) using the BMW Android app. On could setup a sequence for all the lights .
Post #488019 4th Sep 2018 9:03pm
GGDR
Ah I see John, does sound more complicated than my assumption.
But one thought - there is a repeater already - the steering wheel vol. control is a dual control.
I was going to order one of those, or the one I've seen in the rear of the Ultimate Edition.
Here it is in the WM:
These are for the twin iPads and reading that section, they route via an additional box. I don't want to do that, I was only think of the rear seat passengers being able to turn the radio up or down themselves (from one central vol control.
. Cheers, Greg
Post #488023 4th Sep 2018 9:25pm
John w
I assume the steering controls go to a control module that interfaces to the amplifier module, so it is entirely possible you could insert another of these to inject the signals / can messages.
My concern would be how the BCM might cope with an unexpected duplicate module.
If they aren't too expensive it would be worth giving it a go Smile
I've not dug through the manual to see how they link up. Too many toys, not enough time
Post #488026 4th Sep 2018 9:46pm
GGDR
OK cheers John.
I'll study the WM a bit more to see where the steering wheel control goes to.
. Thumbs Up Cheers, Greg
Post #488040 5th Sep 2018 6:36am
