Home > Technical (L322) > Dpf filter full
Rocketuk
Dpf filter full
Hi all on way to work this morning had the red warning triangle flash up with dpf filter full ,and went into limp mode .
Got it booked in at local independent tonight.
Any one had the same ?
Thanks Ryan
Post #488046 5th Sep 2018 8:50am
Paul thornton
http://www.fullfatrr.com/forum/post487225.html#487225
Post #488047 5th Sep 2018 8:53am
GGDR
Did you get a yellow or straight to RED?
. Cheers, Greg
Post #488048 5th Sep 2018 9:24am
Rocketuk
Red only no yellow ?
Post #488067 5th Sep 2018 12:09pm
GGDR
That's weird, first one I've heard go straight to Red.
Can you pls let us know what your Indy says and does?
. Cheers, Greg
Post #488071 5th Sep 2018 1:10pm
Rocketuk
Hi All sorry for the slow update .
So local dealer reset the codes and did a forced regen.
No other fault codes recorded, all sensors and pipes fine
£80 back on the road in a couple of hours.
Ive only had the car since Easter before me it lived in central London.
so hopefully now it gets a good run everyday should be the end of it .
Fingers crossed .
Post #488821 13th Sep 2018 12:14pm
