![]() | Home > Maintenance & Mods (L322) > battery voltage dropping as i watch it. |
D34NO Member Since: 21 Jul 2016 Location: Lincoln Posts: 46 ![]() ![]() ![]() |
Hi all, as the title suggests, my battery light on the dash has recently come on, then one day the vehicle wouldn't start. I got my charger pack on it and it started fine I gave it a good long run yet the light stayed on but the car started first time no problems until this morning, when it was dead. Jump started it to get home, turned off and then it wouldn't start again. I put a multimeter on the battery and it was dropping slowly as I was watching, nothing switched on in the car and not running.
I've not smelt any burning, would the alternator still kill the battery if if the engine wasn't running? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I would suggest you need a new battery, Td6 alternators don't appear to cause problems.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8102 ![]() ![]() ![]() |
How old is the battery ? |
the battery is only 2.5-3 years old I reckon. I'll try disconnecting it and as you say measure it over a few hours. cheers |
If you have another vehicle - take it to Halfords or Euro Car Parts & they will test it for you |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Have you measured the alternator output with your multimeter. |
Not entirely sure how id do that? I took the battery off and charged it over night and part of the day, once I had disconnected it, it measured at 12.02v then I left it till the evening, off charge still, and it had dropped to 11.85v having not been used. I placed it back on the car and it started but as soon as I had switched the engine off it wouldnt start again. i measured the battery on the car and it had dropped to 10.23v........ |
You need a new battery, is it under warranty by any chance |
well that's some relief I guess, instead of forking out for an alternator, I'll look at a battery. I looked through all my paperwork but I can't see anything so can't prove anything for warranty plus the guy i bought the car off said he had put it on new then. 🤥
When you get your new battery fitted you can check the output voltage of your alternator by simply measuring the voltage across the battery terminals with the engine running at about 2500rpm. You should get about 13.9 to 14.2V depending upon what you have switched on in the car. |
That's brilliant thank you. I'll try and get a battery tomorrow and give that a whirl. |
well I've just fitted the new battery (12.53v) and it's starting each time but the multimeter is still saying 11.7v when the engine is running and the battery light still comes on. My iid tool is confirming the voltage too. |
its now steadying between 11.9 and 12v
