![]() | Home > Maintenance & Mods (L322) > Replace Suspension Arm Bushes - What Do You Think? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Ring around some other LR specialist garages close to you.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
It's hard to comment because we don't know exactly what is worn and has to be replaced. In the rear, in addition to the outer upper and lower rose joints (all metal pictured earlier), there are the inner bushes on both the upper and lower control arms. So that's eight bushes and four rose joints. In the front, there are two bushes each side plus a ball joint which they may also be replacing, 4 bushes and to ball joints in total. It's probably more cost effective for the dealer to replace the arms which come already fitted with bushes. I know my local indie does this on the D3/D4. Now, whether the car needs all that is debatable. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
According to the main dealer:
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
My indie recently put mine in for its MoT it passed without issue but they did say they noticed the rear subframe bushes are getting worn but not to worry as they take a very long time worn before they need replacing, and yes it is a big job.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 787 ![]() ![]() |
I’d question whether the bushes are actually broken, they will always flex a bit which leaves scope for a technician to decide they need changing.
Thanks for your comments.
I tried and failed to get some help from LR.
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 ![]() ![]() ![]() |
I would replace the bottom ball joint as well while you are doing it but can be a bitch to get out may need to heat it up.
Thanks, @srpara.
You can just replace the bushes but would need a bush extraction tool or make something up.
Thanks.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
If your "rears" are "on their way out" you may start seeing evidence with increased tyre wear on either the inner or outer edges, and that will also impact on your budget! .
That's the cheapest way to do it, only two bushes to replace on the front (each side) just make sure the swivel joints aren't knackered |
- Fair point. What do I put here then? |
