Home > Technical (L322) > Wheel Tremble
Crusher
England 2009 Range Rover Vogue TDV8 Barolo Black
Wheel Tremble
Just feeling a little tremble in the front - even without the wife being there. There's the vaguest of a front near side tremble between 20-30 mph when bearing left and slowly accelerating i.e. coming off a round about. Seems fine once straightened. Anti-roll bar bushes perhaps? Or would a worn bush NOT cause a tremble? Any thoughts welcome. Thanks.
Post #488154 6th Sep 2018 4:14pm
ChrisJJ
United Kingdom 2002 Range Rover Vogue 4.4 V8 Alveston Red
Get underneath with a pry bar and try moving the joints to see if there's any play.
Post #488158 6th Sep 2018 5:30pm
it can cause a judder, however would check the rear discs and callipers for overheating too. my 2007 had a judder which felt like it was coming from the front, but it was actually coming from the rear callipers binding.
worth checking, that one isn't a lot hotter than the other (and fronts) after a run.
in terms of the front, I would have the wheels off and spun on a balancer. I also spent ages trying to track down a different judder up front which in the end was put down to a tyre out of shape, due to a bent wheel rim. spin them on a balancer and have a look at the wheel as it slows down, to check that the tyre and wheel are nice and round. There is nothing that can't be fixed with a hammer😜😜
Post #488175 6th Sep 2018 8:03pm
Crusher
Sound advice. Thank you. I'm spending the day trying to identify the prob beginning now with a warm up ten miler and will check in later. Just great of you folk to give it a thought. Thank you.
Post #488237 7th Sep 2018 9:24am
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I had the same thing it was the lower arms replaced them and all sweet now.
Post #488447 8th Sep 2018 11:17pm
Crusher
That's what I think now - not a massive amount of movement but I'll get a second opinion tomorrow hopefully.
Post #488476 9th Sep 2018 10:39am
If you are getting new lower arms, go for Lemforder or Delphi, worth a few quid extra.
Also important that they aren’t done on a 2 post lift, or at the very least are torqued up with the cars weight on its wheels, if they are done with the wheels hanging the bush is a long way off the neutral position and if torqued like that will be twisted when the car is put back on the floor.
The new arts won’t last long if they are fitted like that and the inner bush will quickly go south!! There is nothing that can't be fixed with a hammer😜😜
Post #488477 9th Sep 2018 10:44am
