![]() | Home > Technical (L322) > My 2006 wont start at all.. Please anyone help..? |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
Do you get any lights on the dashboard when you switch the ignition on? |
Battery properly connected? (No loose terminals) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
you need a pretty hefty battery to start and indeed jump start the RR, i would try again with a more powerful battery... ... - .- -.
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 ![]() ![]() ![]() |
Sounds like it's a trip to Malayan Motors at Leng Kee Road! Hope they can sort you out without much financial penalty. |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Fist thing that springs to mind is that the car doesn't realise it's in Park, I think sometimes the switch in the gearbox can not work properly. Sometimes by shifting it a couple of times it can be made to work again, or it could be a failed component. Otherwise could it be immobilser transponder? Failure to start would probably be one of these two things if the batteries definitely OK. 2012 SDV8 Vogue SE |
Hleo1 Member Since: 04 Feb 2011 Location: Singapore Posts: 9 ![]() ![]() |
No lights at all when turning key ignition ![]() |
