![]() | Home > General > [SOLVED!] "PARK" / "P" not holding :( |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6421 ![]() ![]() |
Pulled up to a set of traffic lights a couple of days ago, on a slight incline, and put gearbox into PARK as usual, but then clunk clunk clunk it started moving forward! Just stopped in time before hitting car in front |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
I think you're pretty much F*** |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35703 ![]() ![]() |
why? ... - .- -. Y. O. L. O. . |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Are the other aspects of the gearbox fine? Does it drive ok other than creeping forward in Park?
Your park pin has failed. This is generally due to people using park rather than the HB. Happens a lot on big heavy cars.
There's this video of a LRE day, where the instructor point that out.
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
I don't know about the creeping forward but the poor guy in the car behind must have heart failure as the reversing lights come on just as you are about to pull away |
in all the auto's i've had i have always left the car in drive with the footbrake on, except occasionally with the RR the transfer box noise? gets a bit loud because of the 20'' wheels on the car , then i just stick it in neutral. ... - .- -.
So would this have been fitted new as a part of the new gearbox going in - should it have been? Or integral part of gearbox itself? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
It's part of the output shaft - so internal.
It's 27 minutes in if you don't want to watch all the way through No wonder people sit in Drive with foot on the brake ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Thought I would give an update on this. Haven't been to the stealer yet, but the problem is getting worse. I believe it is all about the gearstick not locating correctly rather than the park pin. it is becoming more difficult to select a gear position, and on occasion it will not stay in Drive, just bounces out into Neutral. Also will not locate properly in Park; when I come to start up the car it will not start so have to go into Neutral then start the car.
Which you shouldn't, because the gearbox won't need to be removed to have the problem rectified (if the selector/adjustment really is the problem) = much cheaper for you.
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
i'm the same - leave in drive and use the foot brake ![]() |
