Home > Maintenance & Mods (L322) > Black smoke ( photos )
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Following up on the posts on here about black smoke I had the car on ramps to lube the turbo actuators then run a can of wynns thro the air intake , must admit it seems a lot better ,
So I thought check these two intercooler pipes as the cars been woofing black smoke on hard acceleration and yes you guessed right
And here's the temp repair whilst I wait for new ones to arrive
Went for a quick blast one woof of smoke and then it seems to have cleared
Cheers for the help Thumbs Up
Post #488142 6th Sep 2018 1:59pm
Replace the other side at the same time - it won’t be too far behind Thumbs Up
Post #488161 6th Sep 2018 6:19pm
Henda
Cheers mate ordered two silicone replacements just because they look nice Whistle Thumbs Up
Post #488169 6th Sep 2018 7:31pm
SinbadRose
I don't get smoke or anything, but was thinking of doing the pipe replacement as a "best before it does go" type of job, reading some of the other threads about how some think things like this can cause issues later if they do split, i think i shall do mine when it stops raining.
Post #488190 6th Sep 2018 8:48pm
http://www.fullfatrr.com/forum/topic26843.html
dont accelerate too hard gaffer tape not best solution. will hold well enough under light driving tho Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #488193 6th Sep 2018 8:55pm
Henda
I wouldn't dream of driving my 3.6 v8 beast fast or hard it just wouldn't be right Whistle
Expecting the replacements on Saturday Thumbs Up
As the last post said preventative maintance is a good idea I plan to do little things every month and hopefully keep the ff running well Thumbs Up
Post #488194 6th Sep 2018 9:02pm
Videoman1959
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Can of Wynns?
I had the exact same problem as you with the black smoke. I changed the two BIG pipes under the bonnet and the black smoke went away Smile.
Can you please tell me if the 'can of wynns' is easy to administer and what benefits will i get ?
Cheers. 'Knowledge Is Power'
Post #488618 10th Sep 2018 8:24pm
Injector cleaner is a tip it in a full tank of fuel job. EGR cleaner not so much. There is nothing that can't be fixed with a hammer😜😜
Post #488628 10th Sep 2018 10:57pm
Videoman1959
Injection cleaner
Any particular cleaner recommended for a L322 TD8? And regarding the Wynns EGR cleaner, do I squirt it into the ( as I look at the bonnet from the front of the car) right hand air pipe or left hand one please?
Cheers 'Knowledge Is Power'
Post #488632 11th Sep 2018 7:24am
Henda
If you're using the spray type you can either take the air filter cover off and spray from there or the two intake pipes off at the same place and spray alternately in short bursts
As to the benefits mine seems to be a lot more responsive but on inspection the air filter housing wasn't seated correctly and I did a temp repair on the intercooler hoses as well as lubed the turbo actuators so either of these could have caused the better feel of the engine
On a definite note I Finnish work in the early hours and had a definite rev fluctuation when cold but that has now almost disappeared and there seems to be little or no smoke Thumbs Up
Cheers
Post #488638 11th Sep 2018 8:44am
