Home > Technical (L322) > Remote unlocking stopped working
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
Hi All, Strange one, both remote keys have stopped working at the same time, red lights light,but no worky. Key unlocks and locks car, no alarms. I found a thread from 2014 by rej but it went nowhere. 2007 my bmw style keys.
Post #489125 17th Sep 2018 6:14pm
DavidS
No thoughts
Post #489199 18th Sep 2018 10:40am
Sounds like a faulty reciever unit if it’s both keys.
A few possible clues on this thread - http://www.fullfatrr.com/forum/topic3946.html
Post #489203 18th Sep 2018 12:06pm
DavidS
Thanks Alistair, as you say a clue in that thread
Post #489204 18th Sep 2018 12:37pm
DavidS
After reading the thread Alistair linked to, I tried holding the keys close to where the amplifier is mounted and hey presto both keys work fine , 6ft away by the drivers door (lhd) neither work.
So does this point to the amp or battery low in both keys, I guess that as both keys stopped working properly at the same time it must be the amp, but replacing in hope is not my style, no problem if confirmed, but dislike just changing part until a fault is fixed.
Any further thoughts?
TIA David
Post #489209 18th Sep 2018 1:04pm
CS
If it's working when you hold the key nearer the receiver then it might just be the batteries in the keys, try changing them & see if things improve. Some of the keys seemed sensitive to lower quality batteries so get the best you can. Only Range Rovers since 1988
Post #489221 18th Sep 2018 2:59pm
DavidS
I think I have convinced myself it is the amp as both keys stopped at exactly the same time, so have ordered one, will advise the forum on results in a couple of weeks when it has arrived and been fitted.
Thanks all for the help
Post #489226 18th Sep 2018 3:47pm
07MY have self charging keys so can't change the batteries like on a later model... I would agree the amp is probably the cause Thumbs Up
Post #489243 18th Sep 2018 6:08pm
DavidS
Thanks CTC, my thoughts too
Post #489248 18th Sep 2018 6:34pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I would suggest you try a battery first. Many systems are programmed when the batteries are low to lock but not unlock. It’s a failsafe type situation, you don’t leave your car unlocked but you do know there’s an issue when you unlock it because it won’t unlock from a distance. Batteries are cheaper than an amplifier anyway, give it a go. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #489256 18th Sep 2018 8:11pm
