![]() | Home > Maintenance & Mods (L405) > L405 Headlight Bulb Replacement |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35710 ![]() ![]() |
you mean the xenon bulb???
Diablo Member Since: 22 Dec 2010 Location: UK Posts: 28 ![]() |
Hi,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16344 ![]() ![]() ![]() |
This may seem a lot of work but its the easiest way! Simply remove the air box (top and bottom) on which ever side you need to replace and VOILA |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
Yes the air filter box has to come out , its dead easy after undoing the pipework and then just lift up and at the same time to the centre of the car . Same on the V6 . I suppose its worth mentioning to take the headlight switch out of "Auto" to avoid the lights switching on ! |
Gents, really appreciate the input! |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Can anyone recommend a brighter bulb? And also what bulbs are they?DS2s?
d3s type,
Done and its a 100% improvement |
