Home > In Car Electronics (L322) > Radio / head unit keeps turning off and on
Dinners
United Kingdom 2006 Range Rover Vogue TDV8 Buckingham Blue
as the title really, start up today and the head unit loops into turning on and off.
Checked for water ingress but dry as a bone, tried taking the bluetooth module out by joining the fibre optics but still the same.
Any ideas?
thanks
Post #489250 18th Sep 2018 7:22pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
battery ok?
Post #489278 19th Sep 2018 5:30am
Dinners
Had a new Battery and alternator in Feb this year.....so I had ruled that out.
Post #489288 19th Sep 2018 8:58am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
I had this last year , I replaced the head unit but it still does it after about 40 mins of driving , ive but an android head unit so will set about replacing it asap
Post #489403 20th Sep 2018 1:16pm
Dinners
ok thanks.
So your belief is that the fault is with the head unit rather than anything like the amp or other peripheries associated with the unit that is causing the constant reboot?
thanks
Post #489454 21st Sep 2018 10:29am
An '02 is a different kettle of fish!
However (applies to early and later models) I would have a good look at all the electronics in the left hand rear boot cubby, check all the connections, and you may need to dismantle some of the kit to check for corrosion inside. .
Post #489492 21st Sep 2018 6:46pm
^^ + 1 Thumbs Up
Post #489494 21st Sep 2018 7:06pm
Balloonengineer
I was watching Stephen Kings Christine last night. If yours plays 1950's rock and roll when it does, I would be worried...…….. Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #489531 22nd Sep 2018 8:38am
try a battery reset, mine went into looping on and off on my 07. did it for a few days, disconnected the battery and did a battery reset and all was ok after. though whether that was the reset which did it was up for debate. There is nothing that can't be fixed with a hammer😜😜
Post #489547 22nd Sep 2018 11:16am
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Mine was doing exactly the same checked everything in the boot all connections by passed each unit one after the other to check for faults all ok. I then noticed last of all when I was checking the back of the main head unit there was a TV on the move module fitted to the radio receiver behind the main touchscreen head unit I disconnected this and my stereo has been fine ever since now random restarts etc... So it was a faulty TV on the move module. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #489952 25th Sep 2018 9:05pm
Biggles1957
I know you said no sign of water ingress but have you pulled the plugs and examined the contacts? Mine all looked bone dry but had obviously had water in there at some point in it's life because the contacts showed signs of corrosion...
Post #490035 26th Sep 2018 5:54pm
