![]() | Home > Technical (L322) > missfire issues |
| D17 JWB Member Since: 29 Aug 2018 Location: Olney Posts: 32
Just ebay’d gap iidtool £300ish gulp Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1417
Thats a bargain if its the bt version |
Hawkeye lists 11 DTCs P0490 P02B4 P02A0 P02B8 P010C P010F P023D P007F P0501 U0416 U0002 I have some reading to do.......... Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
A lot of those fault codes are more than likely caused by a low battery..... As they can't say low battery transfer case and hill decent control faults are the norm... normally fixed with a dam good charging!! Yesterday I couldn't spell Engineer... Today I are one!
I took your recommendation it is sitting slumped at Woburn 4x4 as I type Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
I read that a lot in this forum, so the only thing I have done is changed the battery to a Bosch S5 110/920, hoping that was going be the magic cure.................... despite the prayers, ceromony and sacrifice to the Gods the answer was..... NO Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
Well the new battery will have more than likely put out a few of those fault codes, but it wont cure a fuel fault, which unfortunately you have buddy |
D17 JWB Any progress? Yesterday I couldn't spell Engineer... Today I are one!
Thanks holidaychicken, but they can not get it to start. 2006 L322 3.6 TDV8 Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
Yep One turbo seized, one possible oil seal leak. No choice but to repair/replace them and then see if it will start. 2006 L322 3.6 TDV8 Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
Told by W4x4 to not EGR delete the TDV8, fine on all the others but not that engine. As i was starring into the part filled engine bay of my RR looking at all the crud that the Exhaust gas Recirculation process causes I did want to desperatly stop it. Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
Oil in the air intake Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
| All times are GMT |
