![]() | Home > Technical (L322) > TD6 will not crank - immobilizer or other issue? |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Ok , on turning to start the engine , there was no noise, so the solenoid not even moving, the mechanical part was not throwing to engage the motor, this was the dirty bit and completely able to be dismantled ,as long as you can get the bolts out of the starter body( which was my problem and warranted my purchase of another starter) then a good clean up is all you need once off . |
PIMCO Member Since: 30 Jul 2018 Location: Oslo Posts: 44 ![]() ![]() |
So I got the thing off and took it apart today. Apparently it's a re-manufactured unit (had a tag), and surprisingly little crud/dirt inside. I cleaned up what I could, the solenoid is a sealed unit and only the plunger/cylinder and spring is available upon disassembly. I was not able to engage the solenoid - apart from a couple of random jerks - in all the configurations I tried connecting the battery straight to the terminals (out of the two small, I take one is ground and the other is the 12V signal)?
TRy Gentlemen of salvage , not sure of the BMW one as postage is massive.Take time to secure replacement. |
So, I got my hands on a 2nd hand starter from a M57 engined BMW X3. Surprisingly the starter motor/chassis is substantially smaller (and correspondingly I'd assume the kW output), but the solenoid is identical.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
This is the wiring diagram
Two things , make sure your battery voltage and current is up to values, and be sure that the solenoid is cleaned of all contaminated residues, it doesn’t sound as if your far off getting connections , they just need to be improved . |
Thanks for the input!
Your jump start post is the black box that you flip down on the plastic bulkhead in front of the battery compartment unless somebody has removed it and you have a gaping hole.
I am hoping i am not confusing the crap out of you... I think somebody has already mentioned checking the battery terminals are tight....
Many thanks for the going through the trouble of drawing that up! At the risk of asking more silly questions, I don't see a reference to the letters you mention in electrical library? Will check voltage in/out to fuse #5 as well.
The letters on the drawing I put up are what i added to try and show you how it flows through. i used numbers for one and letters for the other, is that what you mean by letters ?
I interpreted that the letters were reference to the electrical library, but didn't see the connection when I looked? The numbers I understand to be the flow of the current, and at which points I should check there to be voltage?
On that last note, I do believe they key will turn in the ignition with the tranny in N (I'll verify this). Does this tranny have a mechanical neutral safety switch on the transmission itself? Would I be able to start it bypass the ignition (start on the solenoid) if NSS was indeed faulty? |
If you tested fuse 53 and have 12.5 ish volts and then both sides of fuse 5( as in the fuse in place you can test the fuses with a pointed multi meter) with the ignition on and you have no voltage then i would say you need to change the lower part of your ignition switch.
