Home > Technical (L322) > Timed climate control
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Hi,my 2008 Tdv8 Vogue's timed climate control worked fine earlier this year during the winter,now when I set the timer nothing happens,when I use the manual switch on immediately button I hear the fans for a minute or so then they stop and I hear a whirring from behind the battery or glove box from inside the car for a few more mins,then silence,I've temporarily removed fuse 59 for a few mins to see if it resets anything to no avail.I definitely have pre heat fitted as it worked fine earlier as mentioned,has anyone please got any advice or solutions before the joy of winter is on us,brrr!Thankyou 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #489658 23rd Sep 2018 11:36am
it may be too warm at the moment for it to turn on, it wont bother igniting if the temp is above a certain figure, which I can't remember off the top.
Edit, that said mine fired up..... There is nothing that can't be fixed with a hammer😜😜
Post #489659 23rd Sep 2018 11:41am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Mine is doing this too, its the battery in my case. The battery starts the car just fine but is apparently too low a voltage to run the heater. I have proved it by leaving a C-Tek charger on overnight and the heater starts up and runs fine. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #489662 23rd Sep 2018 12:24pm
Rapiscan
Thanks guys,I've tested my battery this evening as the car hasn't moved today so I should get an accurate resting voltage i think? The voltage is 11.8v engine off,which suggests it's fubared,though puzzlingly still starts the engine sharpish.I try charging the battery overnight then see IF the heater fires up correctly,incidentally is there such a thing as a nice easy way to charge the battery in situ by simply connecting a plug into the car towing socket wired from a 12v charger to put juice IN instead of crocodile clips onto the battery or would relays etc wired in prevent that method? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #489737 23rd Sep 2018 7:11pm
AJGalaxy2012
If its a 13pin socket pin 9 is +ve pin 13 -ve, if you have the two 7 pin sockets, the grey one (12s) pin 4 +ve pin 3 -ve. BMW i3 Electric Car
Post #489747 23rd Sep 2018 8:05pm
Rapiscan
Great! That's really helpful,thanks! 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #489748 23rd Sep 2018 8:19pm
have a look in the forum shop.......
https://www.disco3.co.uk/shop/tow-electric...c-p45.html There is nothing that can't be fixed with a hammer😜😜
Post #489749 23rd Sep 2018 8:22pm
mjdronfield
Just beat me to it....
I got one of them / these too
https://www.disco3.co.uk/shop/tow-electric...c-p45.html 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #489750 23rd Sep 2018 8:23pm
AJGalaxy2012
Or....
https://www.ebay.co.uk/itm/CTEK-Connection...SwaeRZN61e
and
https://www.ebay.co.uk/itm/13-PIN-EURO-PLA...Swme5ank3M
and make one for a tenner. BMW i3 Electric Car
Post #489759 23rd Sep 2018 9:07pm
Rapiscan
Well I'm stumped over this climate heating! Confused It seems to work only if the wind is blowing from the north and there is a Q in the month!!
I've read low fuel stops it working,so I've kept topped up,I've ensured the battery is fully charged,temp here has been below the requisite 16c yet it still only works when it feels like it,so does the fault lie with the webasto itself or its pump,but why work sporadically if so?If it senses a low diesel level and cuts off,does it need to bleed air out once that fuel is available again?As a great man than me once said"There are more questions than answers" especially with these heaters. Banging Head 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #490648 2nd Oct 2018 11:07am
