Home > Technical (L322) > Coolant level fault
Coconut
United Kingdom 2003 Range Rover HSE Td6 Barolo Black
Coolant level fault
Hi
Have an 03 l322 3.0 diesel
Once the engine reaches temprature after accelerating and decelerating the message check coolant level comes up.
I have checked it numerous times and the level is correct.
Any ideas ?
Post #489862 24th Sep 2018 8:07pm
Baltic Blue
Check the SG (specific gravity) of the antifreeze coolant.
You get a low level warning if it becomes diluted by topping up with water.
Post #489865 24th Sep 2018 8:19pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Sounds like a faulty level sensor or expansion tank if the level is correct.
The sensors can play up & the disc built within the expansion tank can cause the warning to appear.
There are many threads on here to view.
I tried the sensor first (cheapest route), but eventually bought another expansion tank complete with another new sensor & now all is fine.
Post #489878 24th Sep 2018 10:02pm
