Home > Off Topic > DiY
bebechoon
France
DiY
Hi guys!
SWMBO & I moved to the Nice/Cannes/Saint-Raphaël area of France some 8 years ago (some of you will know this), but we have recently upped sticks and moved to a place around 60 km (as the crow flies) north-north-west of Toulouse.
A bit of a change in scenery …
Our new house is very recent and still has a lot of finishing-off to do.
It’s been nearly 25 years since I did any serious bricolage (DiY), which was on a house we had built near Clermont-Ferrand but with only the ground floor (of three) in a finished state.
My goodness, how things have moved on! With the new standards which have been introduced since, I hardly recognise – for example – the plumbing (plastic pipes instead of copper) and the electrics with trip fuses and standard socket fittings for lights (instead of the wires dangling down from the ceiling I was used to and expecting).
It’s a steep learning curve! Big Cry
( Off Topic As an aside, I used to do all the work on our (aged) cars around that time, but bashing things with a hammer no longer works and it seems you need a Masters in Electronic Engineering these days rather than mechanical skills. Most jobs are now beyond my comprehension!)
I suppose a lot of these building standards are EU-driven, but I just wondered if the same “progress” has been introduced in the UK. Anyone care to enlighten me? Thumbs Up
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 8 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #490110 27th Sep 2018 2:53pm
I’m on a house project too - it’s pretty much the same in the U.K. - it’s all plastic pipes, MCB’s and RCD’s - Aluminium windows and doors are the thing again - albeit dark grey is the colour to have
Tools have moved on a long way too - I bought a DeWalt 18v kit and the stuff is more powerful than my old mains powered kit Shocked
Post #490129 27th Sep 2018 7:49pm
fisha
There are now a lot of regulations that need to be followed to when doing 'new' work. ( As opposed to "it was like that when we bought it" Whistle )
It also leads to a considerable amount of debate on the best manner to do things on forums ( diynot.com for example ).
The current standards and basics of most work is easy enough to follow based on guides and diy books, the trouble is that when you go through the proper planning and approval process, for formal completion you have to get the work carried out 'signed off' by a recognised/approved person. Which personally i find a pain in the hoop. i.e. I have a degree in electrical engineering and I'm not considered suitable to wire up a socket in the house !
As for plastic pipes ... I'm a fan in some areas, and not in others. For example, in my old house, I used single runs of plastic pipe from the central heating manifold to each radiator without any joins. Gave me great peace of mind in terms of not having the worry of joints leaking behind walls.
That being said, I prefer the strength and look of brass / copper plumbing. V8 or else ...
Post #491345 7th Oct 2018 7:05pm
there is some confusion as to what can and can't be done diy. So long as a competent person will sign it off then you can do most stuff. in terms of electric, if you add a circuit then it needs signing off, but simply swapping face plates etc that is DIY.
I re did my kitchen last year, and I didn't re wire it but did move some things about a bit. and whip some face plates off etc. The building control officer was happy with what id done and as I wasn't adding to the house it wasn't a problem
similar with plumbing, though there are many actual regs to get your head around in terms of pipe rings and even waste systems, its all doable. Gas is the only really big No no to have a go at. You can install a boiler yourself, do all the pipework and connections, but it is not allowed to work on live gas so that bit needs doing by a competent gas safe person who can then check everything you have done and get it signed off and registered with gas safe.
our new builds are required to comply with all the latest regs obviously, but that doesn't mean that we can't get involved with things like first fix electrics and plumbing, we tend to use our labour alongside the electricians and plumbers to reduce costs while making sure that everything is done properly.
plumbing is now pretty much all plastic,
wiring is pretty straightforwards but I can't remember the last time bare wires would have been allowed.... There is nothing that can't be fixed with a hammer😜😜
Post #491363 7th Oct 2018 9:15pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
" for formal completion you have to get the work carried out 'signed off' by a recognised/approved person. Which personally i find a pain in the hoop. i.e. I have a degree in electrical engineering and I'm not considered suitable to wire up a socket in the house ! "
Not true. Two avenues are open to anyone undertaking what is known as 'notifyable electrical work' i.e. new circuits, wet spaces such as bathrooms or kitchen etc... you either get it signed off and certified by a competent person who is a member of a recognised professional body OR you can get the local authority / building control surveyor to undertake checks as part of a formal building regulations application. Councils would rather you not know this. Most councils would rather you did not use them as they tend to know the square root of sod all when it comes to electrics and often have to employ their own consultants.
The current building regulations are a farse. I know I work with them all day. The Gov guidance known as approved documents are in the main over complicated and difficult to grasp. Approved Doc B deals with means of escape and fire spread - Grenfell need I say more. Yet again it will be changed as a reaction rather than a proactive move. Part F (ventilation) is complete mad. Part L deals with thermal insulation and you need a degree in physics to understand it. I could go on but I'm even boring myself now.
Laying foundations, building walls and putting a roof on are all just as simple as they were - as for the rest of the build - madness. Evil or Very Mad 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #491484 8th Oct 2018 8:43pm
GP 225
England 2003 Range Rover Vogue Td6 Zermatt Silver
Northernmonkey, I’m afraid you’re incorrect regarding the gas.
Any gas carrying item, be it pipe work, boiler etc has to be installed by a competent (read Gas Safe registered) person.
You can’t diy this and get it signed off.
Any self respecting gas safe registered engineer would refuse to sign it off.
Yes I know, it’s crazy.
Post #491536 9th Oct 2018 8:32am
