The heater has stopped working in my 2007 TDV8 (ford)
I've bled the system as you normally would but still no heat.
So I took off the pollen filter and checked the heater pipes as they enter the matrix - they are cold
I then took off the pair of clip-on water hoses on the top of the engine that feed the heater and water is being pumped out of the feed pipe.
So I now know water is getting to but not getting round the heater matrix.
The only component before water reaches matrix is the "heater valve" - so it could well be this but I have no knowledge of how to prove it
Does anyone have any tips as to testing this item or the symptoms you get if its faulty ?
It may not be this at all so if you have other thoughts please share them !!
