![]() | Home > Maintenance & Mods (L405) > Front Fog Lamps |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 ![]() ![]() ![]() |
Has anybody fitted front fog lamps to a L405 VSE? Is the wiring present? Do I just need 2 fog lamps and a new Indicator Headlight Switch Stalk? |
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 680 ![]() ![]() ![]() |
I believe it is financially prohibitive . |
Do you mean it needs more than the lamps and a switch 362bkr? Cheers Ian
Only standard fitting on the AB. |
Thanks for that, I was surprised when they weren't fitted as standard |
Nig Member Since: 27 Jun 2018 Location: Lancashire Posts: 11 ![]() ![]() ![]() |
If I recall correctly fog lights were a £150 extra on my L405, was plug and play on my P38 as an after fitment, someone’s grabbing the cash 💴 L405, MY14 3.0 V6 |
I think you may need a bumper loom too I'm afraid... |
Cheers guys, I did wonder if it was just a case of plugging them in like a lot of things on Discovery's but it looks like it may be a bit more involved |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8114 ![]() ![]() ![]() |
Do you actually need them ?
I don't actually know whether I 'need' them as such as I haven't had the car for long, it was only earlier on this week that I drove it in the dark for the first time, |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
Its bonkers LR don’t fit them as standard - they were only £116.67 ex vat to fit when I bought mine - plus the an extra £25 ex vat for the extra windscreen washer bottle. They then charge £3k extra for Turbines, the pathetic extra time involved in admin fitting the fogs and washer bottle and the tiny sum generated they would be better off fitting as std. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931 ![]() ![]() |
They were £3750 on my new VSE , but............
JLR are clearly worried about your eyesight if you order Green |
kiwirich Member Since: 19 Nov 2011 Location: Toowoomba Posts: 6 ![]() ![]() ![]() |
Good Morning gents,
