Home > Maintenance & Mods (L322) > painting rear exhaust 'box'
Page 1 of 3 123>
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
now i've confirmed to you all that i'm mad Very Happy
anyway, the large rear 'box' on my 4.4 v8 is clearly visible and areas of the black 'coating' have come away leaving shiny steel patches - quite simply looks unsightly
so i want to repaint the box - have looked at exhaust paints mostly used for bikes and they are ok to about 600 degrees
so - anybody done it and any recommendations?
thanks in anticipation
Post #48948 5th Feb 2011 1:47pm
done the exhaust and anything else i could under the back of the range ..used wickes 'direct to metal' paint ......... ... - .- -.
Post #48952 5th Feb 2011 1:57pm
dan_uk_1984
I dont think the rear box gets all that hot. So you should be OK with most paints I guess.
Post #48955 5th Feb 2011 2:00pm
nick h
thanks guys - not as mad as i thought - Rolling with laughter
Post #48958 5th Feb 2011 2:19pm
I have painted loads with any heat resistant mat or satin black paint. Even Barbeque Spray paint is effective as its totally heat resistant.
I think Satin Black heat resistant looks best. Lots of bits you can spray under there and it looks great after just a few minutes work but be careful not tape off anything you want to avoid Thumbs Up
Post #48962 5th Feb 2011 2:29pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
I can't stand sight of mine, so thinking about dumping and replacing with custom twin pipes like the supercharger exhaust. Nothing larey, just oem style. Seen Midlands exhaust do set up on ebay for 260 so going to look local for similar set up.
http://cgi.ebay.co.uk/Range-Rover-Land-Rov...41557211ef
This will lose the box completly and just have to shiney new pipes Thumbs Up
Post #49013 5th Feb 2011 8:15pm
dan_uk_1984
Not my cup of tea - I think the fact you cant see the pips on the RR is classy.
Post #49017 5th Feb 2011 8:24pm
M44K TS
Satin black high temp paint has worked a treat on mine, just give it a quick once over every few months to keep it looking tidy Thumbs Up 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #49019 5th Feb 2011 8:28pm
Nickj
But on the supercharger you can just see tips which is classy and cool. I just want a S/C exhaust on my 4.4 really. Do they fit??
Apolagies about asking q's on your thread but think you've got your answer. Paint it now and we are all as mad as each other!!
Post #49024 5th Feb 2011 8:33pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Did mine with matt black exhaust paint from my local autofactors.
Made a big difference to the rear as mine was also peeling/patchy. TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #49032 5th Feb 2011 8:56pm
i think all exhaust show the 'silvery metal' bit after a while and it is so easy to put the RR into high mode and walk Very Happy underneath and paint.. ... - .- -.
Post #49034 5th Feb 2011 8:59pm
daveo
i used satern black paint, the box does not get hot at all, just give a going over with wire wool and your ready to go...looks the part when done, when i am ever behind a rr i always look at there back box...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #49069 5th Feb 2011 11:03pm
Nickj
That looks superb! Did you remove the box to paint or leave in situ. What pipes have you added and where from at what cost if you don't mind me asking!!
Think i may have just found my next task.
Post #49073 5th Feb 2011 11:39pm
Nickj
Any more pics from the side maybe?
Post #49143 6th Feb 2011 10:54pm
daveo
http://www.fullfatrr.com/forum/topic2333.h...arge+trims V8 facelift Range Rover Autobiography 22" wheels.
Post #49147 6th Feb 2011 11:33pm
Page 1 of 3 123>
