Home > Maintenance & Mods (L322) > TRANSFER BOX
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
TRANSFER BOX
Post #454962 22nd Oct 2017 7:09pm
thanks again Wink , wiki'fied.. ... - .- -.
Post #454964 22nd Oct 2017 7:23pm
EmiratesA380
Stan - all part of being a Fullfat member !
Cheers Fella
Post #454965 22nd Oct 2017 7:26pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Gents
Just stumbled on this post from a couple of years ago, am planning to do my diffs and transfer box oil this week.
Emirates for the transfer box you say wet or dry fill is 1.5 litres? But i looked on a workshop manual online and it says dry fill, 1 litre?
Will i need more, as I bought only 1 litre to do the job?
Post #490489 30th Sep 2018 11:28pm
RRPhil
You have the earlier New Venture Gear NV225 transfer box (1 litre capacity) which was used with the 5-speed transmissions, not the later Magna Steyr DD295 unit (1.5 litre capacity) which was used with the 6 & 8-speed transmissions.
Phil
Post #490490 1st Oct 2018 12:26am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Go by the manual, the posting above is for a 2006/7 onwards model L322 (2006+ Petrol/2007+ Diesel) which have a different transfer box (Magna Steyr DD295) for the 6 speed transmissions compared to the transfer box (New Venture NV225) fitted to the earlier 5 speed transmissions.
The earlier 5 speed models have a Torsen diff inside the NV225 box and the required oil for it is Castrol BOT26FMB1 and takes 0.996 litres.
http://www.fullfatrr.com/gallery/albums/us...ferBox.pdf
You need to use the correct oil and don't substitute the later oil as the later DD295 box uses a completely different conventional plated diff design and hence a different oil is required.
Likewise for the front and rear diffs, go by the manual for your vehicle as there are different types of diff out there (e.g. some Supercharged models got an electronic locking rear diff). If yours is an early TD6 then it'll have open front and rear diffs.
Post #490491 1st Oct 2018 12:58am
mrblonde
Cheers guys
I got 1 litre of Castrol BOT 26 FMB 1 STC4861 Fully Synthetic Transfer Case Oil from somewhere and its got LR RR labelling on it Thumbs Up
Post #490493 1st Oct 2018 1:30am
If you find you need more oil let me know Smile
http://www.fullfatrr.com/forum/topic48090.html .
Post #490501 1st Oct 2018 8:15am
EmiratesA380
Transfer Box on 4.4 V8
Post #490532 1st Oct 2018 12:56pm
mrblonde
Will do Joe, im hoping that i dont though... she had more than enough spent on her this last couple of weeks (and coming weeks)
Post #490580 1st Oct 2018 6:27pm
mrblonde
Re: Transfer Box on 4.4 V8
EmiratesA380 wrote:
Thanks emirates, my bad. I blame the fact I was still awake so late at night Embarassed
Post #490581 1st Oct 2018 6:28pm
EmiratesA380
mrblonde A Pleasure
Good luck Fella.
Post #490592 1st Oct 2018 7:13pm
mrblonde
cheers mate, new washer on both drain and fill plugs, for all 3? (front and rear diffs, and transfer box)?
Post #490593 1st Oct 2018 7:32pm
EmiratesA380
mrblonde
Post #490639 2nd Oct 2018 8:03am
pld118
Confused
Post #508174 10th Mar 2019 1:21pm
