![]() | Home > Technical (L322) > Dropped suspension on my l322 |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Could it have been this way before your suspension work. If you have an IID tool you can reset the heights to the correct level. 2015 4.4 AB
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 336 ![]() ![]() ![]() |
The joints should be tightened when the weight is on the wheels - could this be it? 4.2 SC - sold , now bought back
duplicate 4.2 SC - sold , now bought back
petebowling Member Since: 17 Jul 2018 Location: Thetford Posts: 20 ![]() ![]() ![]() |
I didn't do it that way weight was off, can it be jacked up without wheels on to put weight pushing upwards or do I need to have the wheels on? |
The levels were ok before the work, I have a Hawkeyes can they be reset from this |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
You will need to loosen off the front suspension nuts/bolts for the wishbones, get weight of car on the wheels at "normal height", then tighten up the bolts. Only then should you try calibration.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Simply ask the garage doing the alignment if (maybe for a small fee) if you can put the car on the alignment ramp and loosen/re-tighten the wishbone bolts... That way you can do all the tightening with the wheels on the floor albeit on a ramp... |
What's a iiD tool? is that like a LR Hawkeye diagnostics tool |
https://www.gap-diagnostic.com/products/iidtool/ .
