![]() | Home > Technical (L322) > Rear ventilation button |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
default seems to be 'on' whether you switch it off or not..
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
It sort of bugs me too. I can count on one hand the number of times peeps have travelled in the back of my car, so I’d like to know what it’s doing...is it just heat? If I have AC on full cold I assume rear will blow same, irrespective of button? 2011 Range Rover Vogue SE 4.4 TDV8
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
It does bug me but when my 2007 was the other way i hoped there was an easy fix , something like holding it in for 5 seconds or the like.
| John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447
I found on mine (2011 spec, 4 zone a/c) that if I set the fan speed from the rear seat control to minimum, it doesn't come on.
Which one on here? It’s either for auto fan or auto air distribution on knob 7, or auto/always on/always off air recirculation on button 1.....I would imagine.
Hi , if the diagram is for me , its not on that picture, the switch is under button 1 on the diagram/ picture. 2015 4.4 AB
this,
Thats it Stan |
Sorry, it was for John W.
Stan beat me....again. 2011 Range Rover Vogue SE 4.4 TDV8
| Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121
According to the manual, it is called the rear control isolation switch.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Fart diverted button.
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
Agreed it is a bore to have to switch it off every time. I'm not aware of it being possible to programme it otherwise. I got used to it. Only Range Rovers since 1988 |
| All times are GMT |
