Home > Maintenance & Mods (L322) > Tow bar loom is it complete
deltic
Ireland 2005 Range Rover SE Td6 Bonatti Grey
Hi all, i got a tow bar 7 pin with the loom and ecu it from a 2002 l322 was going to fit this and when i opened up the box the loom was cut in two the breakers cut it about 10inches from where the white connector and the black one on the ecu. The thing is the wires are cut uneven and it looks as if some/thing is cut out of the loom would i be right in saying that the wires from the tow bar plug in socket go straight to the white and black plug connectors and there is nothing in between thanks
Post #490607 1st Oct 2018 10:06pm
No there is an ECU in between sir...
See here Thumbs Up https://www.google.com/search?q=l322+rover...KJrz87GDM:
Post #490611 1st Oct 2018 10:21pm
deltic
Thanks I have the ecu i was going to solder the loom and i just wanted to know if the wires that go from the 2 connections in the rear right panel to the tow bar has nothing missing the way it was cut looks odd i is it just wires that go from the 2 blocks down to the tow bar in the loom there is no other electrics sorry i cant download photos
Post #490621 1st Oct 2018 11:29pm
