![]() | Home > Maintenance & Mods (L322) > URGENT HELP please - loud bang and dropped suspension |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
The bang would make you think it was an suspension airbag 2015 4.4 AB
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
I thought that too, but it looks as though both fronts have dropped to their absolute minimum, if 1 bag had gone id of expected one corner to drop?
I'm far from an expert so take my thoughts on that basis |
sorry dolph, bombarding you this time of night mate |
No problem , nothing worse than not knowing what the problem is. If it was mine i would start it and trace the leak , good chance it a front bag if the front is down. To find the leak its simply a case of listening for the air and that will hopefully help diagnose the issue.
Just been out and checked, tried to raise the car and you could hear a loud hissing of air from front passenger side wheel arch, and my mate could see the airbag start to inflate then deflate again.. so guessing it’s a new bag needed (will do both fronts together)
They seems to be differing opinions on the different brands of bags, personally i use OEM quality but wouldn't buy Land rover branded goods BUT thats me, others on here with way more experiance swear by genuine. Each to their own. Probably best to change both bags if you are keeping the car long term, again personal choice and your available funds.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Delphi are good quality
Thanks Grofus.... ended up ordering Delphi complete units so hoping they arrive for the weekend. Saw the videos on YouTube so looks fairly straightforward
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
If you get in and start it, can you not drop the rear down to normal or even access height ?
Hi John W
Check the compressor connections - you have two, one to the front, one to the rear. Make sure they are both snug. Worst case (and be careful) is to disconnect them - this will bring the whole system down to the bumpstops - there is a LOT of pressure when you release them without an IID to depressurise though - so be VERY VERY careful |
2 connections on the compressor itself? Will it be easier to move on all 4 bumpstops? I really dont fancy driving it at all so hoping the AA will recover it back for me |
driving it on the bump stops is not an issue as long as you do it at reduced speed (i.e. 30mph max).
