![]() | Home > Maintenance & Mods (L322) > URGENT HELP please - loud bang and dropped suspension |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
Hi just changed front strut on mine .Take inner liner off find block with air lines leading to top of strut unscrew the pipe leading to airbag disconect battery first that will deflate bag .Mine had a hole in it so I managed to change strut without deflating first as it was already flat good luck |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
Hi just changed mine on my TD6, the drivers side went with an almighty bang then hit the deck. Drive the 1/2 mile home and the passenger side had deflated.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
You could probably apply voltage to the solenoids to let the rear down.
If you access the valve blocks behind the wheel arch liners, you can undo the brass nuts securing the pipes, do it slowly, and this will gently release the air in the bags. Rear (and front) valve block is drivers side
Nice link Joe |
If the bag is burst it won't be pressurized so no need to worry |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Cheers all, makes sense now. For whatever reason the drivers side either depressurised, or burst at the same time as the front is equally as low on both sides, so as long as i disconnect the battery the system will stay depressurised
Looking at the front of the car it looks like I could pull the old bag out now, without even jacking it up ![]() Rear is a different story though, higher than I've ever seen it so ill need to depressurise that so that it will actually sit on axle stands when they are under it.. you could drive another RR under the rear at the moment ![]() |
If you can't get to the valve block, you can crack off the connections to the compressor itself. Assuming TD6 is similar compressor wise to the TDV8 there is a valve block on the compressor - you will see the air in/out to the compressor and then hoses disappearing off into the car - these are the ones to undo slowly. Land Rover Addict
Unnecessary quote removed
It doesn't matter how much you let it down, the car 'should' sort itself out as there are height sensors each corner.
Information about Extended mode for the 2016 RR, but L322 may be similar ?
You can activate super extended mode my wading up to the windscreen through a river ..... please don't ask how I know |
