|  | Home > Technical (L322) > Engine system fault, now won't start - 4.4 TDV8 |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | Dunno Ant, but whatever it is you need it done under warranty right?
|  30th Sep 2018 9:29pm |
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198      | I'm going with gonna_go, get it recovered to your dealer and tell them to fix it. You should, I believe under legislation, have six months, irrespective of their arguments, to have them repair any fault which may have been present or developing at the time of your purchase.
|  30th Sep 2018 10:36pm |
| John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447      | The gearbox fault is almost certainly because its been put manually into neutral to move it. I'm not sure if the manual says how to revert this or not.
|  1st Oct 2018 11:48am |
| Ant84 Member Since: 17 Jul 2018 Location: Billinge, Wigan Posts: 16    | Struggling with this.
|  4th Oct 2018 12:11pm |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | If the battery is low then various non-critical systems that use significant power will be shut down, eg the suspension system.  Can you monitor battery voltage with the ignition on then also while trying to crank?
|  4th Oct 2018 12:27pm |
 That's a valid point actually. Last week I was driving on the motorway and my gauge showed 65 miles remaining. A few seconds later the low fuel warning came up and it showed '--- miles remaining' - which corrected itself around 5 minutes later and went back to 50 miles remaining. | ||
|  4th Oct 2018 12:45pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | sender units are a known issue.
|  4th Oct 2018 1:14pm |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027      | Cheap bluetooth readers won't give you real LR DTC's - you need an IID. ANYONE near you can plug an IID and check the codes for you - they just can't make changes to your vehicle. Land Rover Addict
|  4th Oct 2018 1:15pm |
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 548      | I would charge the battery overnight and see if it starts cranking again. If it does, check the fuel gauge reading as mentioned above. On pre-facelift cars (not digital dash) the sender issue is annoying (ask me how I know) but I don't think it causes issues with running. I'm sure I read on here though that on later cars it can cause faults if the car thinks the fuel level is too low.
|  4th Oct 2018 4:42pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Flack is a Disco 4 forum sister site sponsor
|  4th Oct 2018 4:58pm |
| Ant84 Member Since: 17 Jul 2018 Location: Billinge, Wigan Posts: 16    | These are the readings taken by my diagnostic tool. Not sure if there are any glaring issues here?
|  4th Oct 2018 10:06pm |
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797    | I’d start with checking the basics first.
|  5th Oct 2018 4:27am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | That's the high pressure fuel pump, probably cavitating due to getting air instead of fuel. Put fuel in the tank before trying to start lest you damage the pump, hopefully not already done. | ||
|  5th Oct 2018 8:10am |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2782    | The battery is a tad small but will probably suffice. | ||
|  5th Oct 2018 8:12am |
| Posting Rules
