Home > Maintenance & Mods (L322) > Heated Seat.
Can't those with warm hands warm up those with a cold bottom? Shocked
Post #306278 19th Jan 2015 11:42am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Interesting - I bought my 2010MY 4 days ago and have been back to question them on it. To me they hardly heat up at all to be honest...
Thx Craig - will check the filters first to see if they are clean/clogged up. Is it still warm air that heats them though rather than an electric "under-blanket"? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #306355 19th Jan 2015 7:37pm
supershuttle
I'm just gonna bump this to see if I get any answers. My 2010 seems to have an intermittent fan under the drivers seat, it's quite handy that you can just stick a finger in to see if it's spinning. Has anyone else had this? Is there a fix? Does anyone have the circuit diagram - or is there one in/on TOPIX.
I'm a bit stuck - sometimes with a cold bum sometimes with a warm one! Geoff
Post #307468 23rd Jan 2015 5:13pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Geoff,
I have the same problem with mine Shocked I have tried three different modules under the drivers seat but have finally isolated the problem to the seat back!
It would seem that when the seat back is lowered towards the rear all works fine but as soon as I rest my back on it the fan stops spinning and shuts down. This would imply that either my back is stopping the air from circulating or the more likely explainaition is that pressure on the seat back is expanding the probable crack in the plastic. I won't know for sure until I get round to examining it Big Cry
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #308348 26th Jan 2015 9:07pm
supershuttle
Ah well, I found that as I can feel the fan under my seat, the filter has fallen off again, and if it doesn't start spinning on switch on I turn it of and turn it on again - the trick seems to be to turn it on slowly.
So far I have had 100% success with this method Thumbs Up Geoff
Post #308355 26th Jan 2015 9:41pm
supershuttle
Sometimes the turning off turning on trick doesn't work in which case I have to turn off and turn on the car (restart) after a few miles as the IIDTool pointed me in the direction of the drivers seat heater losing contact (or maybe never even making contact) with the appropriate ECU.
I think this maybe due to low battery if the seat heating is operated immediately after starting the car - maybe!
It's a pain in the ass having to stop and restart the car but its better than having a cold ass!
Oh and it works 100% so far Very Happy Geoff
Post #311488 8th Feb 2015 10:23am
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
I'll swap my 2003 for your 2010 if you like. My seats heat up super quick! Whistle
Post #311953 10th Feb 2015 1:02pm
Lanby
2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Supershuttle, did you get a resolution to your heated seat problem as mine has started doing the same?
Cheers
Post #321369 5th Apr 2015 9:14pm
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Not sure this helps but we had similar issues with a vented seat. Turned out that a pipe joint between the base and seat back had come undone. Resulting in hot air being blown over one of the hearting unit causing the unit to cut off thinking it was warmer than it actually was. As I say not sure this helps but having spent 6 months getting to this stage including replacing one of the blowers my recommendation is to dis assemble the seat and see what is going on properly. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #321696 7th Apr 2015 8:50pm
DrRob
Cam-Tech-Craig wrote:
RRUK wrote:
Because the climate seats are air heated and cooled the engine needs warmth to heat your backside.
Adam, there is a separate heater/cooler unit for both the backrest and the base... Neither of which has anything to do with the engine temps sir...
Geoff, There is an air filter for each unit (4 in total) they are changed as part of a service (can't remember which one at this time of night) So, maybe a blocked air filter?
One filter is under the front of both seats (a white foam disc filter) the other one is behind the map pocket in the backrest...
Craig
Are these the filters?
https://www.island-4x4.co.uk/seat-filter-g...36870.html
How many per seat? 1 or 2? Your post suggests 2per seat Thumbs Up
Ta
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #491241 6th Oct 2018 8:50pm
Thats them Rob, two per seat sir... One in the base and one behind the map flap in the back Thumbs Up
Post #491243 6th Oct 2018 8:53pm
DrRob
Cheers! I’ll check out the front 2.
Not sure I know how to remove the seat backs...probably break something knowing me Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #491248 6th Oct 2018 9:01pm
GGDR
A bit of light reading for you here Dr Rob:
http://www.fullfatrr.com/forum/topic44946.html
. Cheers, Greg
Post #491249 6th Oct 2018 9:10pm
