![]() | Home > Maintenance & Mods (L322) > Front fogs (LED) flickering? |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I dont know about Land Rover but some cars (my VW Touareg) used to pulse the bulbs for a very short time, not enough to heat up a conventional filament bulb to test if it was there and OK. LED's react quick enough to illuminate at full brightness momentarily. It sounds like may be a possibility. BMW i3 Electric Car
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
the FF has hot and cold bulb monitoring..both can be switched of with the iidtool.. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Exactly the same as the VW system described above... Known as Hot & Cold running as Stan says above |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
cheers all, so nothing to worry about |
Yes & No sir.....
Ahhhh good point....
Every day an education! thanks guys I didnt know about hot / cold monitoring or that it could be turned off with the GAP tool. BMW i3 Electric Car
