![]() | Home > Maintenance & Mods (L322) > 7 pin to 13 pin tow electrics conversion |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Has anyone fitted a 13 pin tow plug to their FF?
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
It looks like the 12N maps exactly to the same numbers of the 13 pin, only when you get to the 12N do things start to get a bit iffy!
Actually here's the cross map: -
That’s the same wiring diagram I’ve been working to except for pins 9 to 13 are different colours to what’s in my loom |
Pin 4 from 12S (Green) to Pin 9/13 (should be orange) Current: 2011 FFRR Vogue SE 4.4 TDV8
The only thing I'd be worried about is the gauge of the wires you have from your loom -- a lot of the wires you're dealing with from now on in should be a thicker gauge! Current: 2011 FFRR Vogue SE 4.4 TDV8
I’ve only got the one green wire and I’ve fitted that to pin 4 on the 13 pin plug as per the diagram above. |
This is what’s left.
Yes, sorry I see the dilemma now, sorry assumed you knew the original pin locations |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8772 ![]() ![]() ![]() |
for the tin tent there is nothing which needs a perm feed from the car afaik. Fridge and charger will be 12v switched. so if that is all you have....... There is nothing that can't be fixed with a hammer😜😜
4 is all that is required, beyond the pink already done -- but that's me assuming they map colour for colour -- which I'm not sure they do -- I was working pin to pin if you see what I mean!
It’s a two year old Swift with the LED tail lights. Not all cars work with them and mine is one of them. The LED indicators flash rapidly and in answer to this, Swift retrofit a module to the caravan. However there are several different types of module depending on what kind of car you have. They couldn’t test my FF as there was no live present which I’m told is pin 9 (orange).
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Try this, my electrics had been on fire!
Makes sense. I’ll test them and see. I seem to recall on a previous project, the yellow and brown being permanent live. |
