Home > Technical (L322) > 2011 4.4 TDV8 Charging system fault, performance restricted
To replace the belt is a load more work sir... If the belt is good, i would leave it well alone... The tensioner can be changed quickly and cheaply, with minimal expense Thumbs Up
Post #491403 8th Oct 2018 10:22am
had a look at mine and its pretty much all on the tensioner Whistle except about 1mm at the top.
Probably worth changing as a precaution Craig? I am getting Dan to price me one up now. the rave page shows it being bolted on with 2 nuts at the top, so doesn't look to bad a job, especially with my recent front of the engine experience of swapping the alternator on the D4. There is nothing that can't be fixed with a hammer😜😜
Post #491458 8th Oct 2018 6:26pm
GGDR
Can you post the price from Dan when you get it pls NMJ?
. Cheers, Greg
Post #491488 8th Oct 2018 8:59pm
LR022809 - LR direct price £145.
Waiting for dan in the morning. There is nothing that can't be fixed with a hammer😜😜
Post #491504 8th Oct 2018 10:31pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Had mine replaced last year as it was cracked, £105.66 from my indie, they had to change the idler pulley as well as the bearing was shot.
You could hear it making a noise if you stood at the front of the car.
Ian
Post #491541 9th Oct 2018 9:00am
112 from dan so similar. There is nothing that can't be fixed with a hammer😜😜
Post #491548 9th Oct 2018 9:18am
