Home > Technical (L322) > Inspecting the turbos when buying a 2007 TDV8 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
The turbos aren't necessarily the issue (although they can be), more likely the EGR valves (these disintegrate and destroy the turbos and engine)
8th Oct 2018 7:35pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
While I haven't bought the car, I've already ordered the EGR blanks to block these.
8th Oct 2018 7:38pm |
Double it if you get a garage to fit .
8th Oct 2018 7:42pm |
Probably triple on this side of the pond.
9th Oct 2018 4:32pm |
http://www.fullfatrr.com/forum/topic17623-90.html
9th Oct 2018 4:36pm |
Much appreciated. |
9th Oct 2018 4:37pm |
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 |
It's a good idea to have the induction system cleaned also. This will remove carbon deposits on the EGR system and the turbo blades: mainly on the ends due to centrifugal forces, I believe these deposits ultimately start the vibration/wear that leads to failure of the turbo. |
10th Oct 2018 2:41am |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
From what I understand and have read etc. changing both turbos properly requires dropping the entire engine/gearbox/subframe assembly out of the bottom of the car. People say you can do the right hand (UK drivers side) turbo with engine in the car but the other side is impossible.
25th Oct 2018 11:43pm |
Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116 |
Is that some kind of Terraclean type thing? |
31st Oct 2018 11:59pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I used Revive induction cleaner on mine. ______________________________
1st Nov 2018 10:13pm |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 |
Yup its easily a £3000 job. If you take it to LR you can add a few more £££ to that
5th Nov 2018 10:13pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1194 |
I used midland and they did both the turbos completely and other bits on them and i sourced two genuine brand new egrs and all done for the lot inc fitting etc and back on my drive was 2800 _____________________________________________________
6th Nov 2018 12:20pm |
I finally got around to removing the bottom IC-hoses for inspection.
11th Feb 2019 6:09pm |
I looked at mine when I was worried about possible rh turbo trouble. The bottom hose had virtually no oil in it. Didn't check the left one to compare. At that time the car had done around 120K miles. Both EGRs were replaced at about 114K. The problem I was having with the car - P023D code from memory - turned out not to be turbo related. Now at 129K. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
12th Feb 2019 9:34pm |
