![]() | Home > Technical (L322) > Need a 4.4 TDV8 FBH guru |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102
Hi folks,
Thanks Dolph, in the wheel arch? Current: 2011 FFRR Vogue SE 4.4 TDV8
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
Yes sir, on a cold day it can scare the hell out of you when you see smoke coming out the side of the car. 2015 4.4 AB
Well that would explain why I can't find it then.
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 913
As Dolph says, it's behind the nearside wheel arch, under the battery.
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
Remove batteries from remote for 30s. Replace batteries. Pull fuse 16 in the boot. Hold off down on the remote. Push fuse in while continuing to hold off on the renotr. Wait for remote to flash. Job done. Did it last nihht on mine |
Not connecting the fan is unbelievable, a friend of mine with a 2 year old merc had a similar problem when a merc main dealer forgot to reconnect the fan , my friend has no mechanical knowledge or common sense and kept driving it on a hot day a blew the head gasket, i had a quick look and the fan connector was lying loose !!! It might be worth a check to see if its all connected up as it should be. Did you try running it from the display screen ? 2015 4.4 AB
No, only tried running it from my IID tool
Well that means it's paired. There must be another issue if its now not firing. Does the vertical orange light come on in the cabin when you press on - I fact does the light on the fob go from Amber to green? " Land Rover Addict
No, pressing the on button on the fob just results in red flashing LED
I'm on my mobile so can't see what version of the l322 you have. If it's pre 09 then it's above the 'on' switch for audio etc.
It's a 2011, will give it a go tomorrow morning |
| kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386
I would have thought the remote is irrelevant. It should operate from the IID Tool. I assumed this would be independent of outside temperature since it is for diagnostic purposes.
As far as I can understand IID does operate regardless of temperature.
| All times are GMT |
