![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Belt tensioner replacement |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
Great write up, nicely done thanks. May I ask the approximate cost of the tensioner and do you have the part number?
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Tensioner was £112 from Dan (duckworthparts)
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
i've taken the liberty to wiki'fy this Mark.. |
| JWL Member Since: 07 Aug 2016 Location: North Wales Posts: 42
Great write up - thanks.
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1211 |
Good, write up many thanks on my to-do list. |
the belt is not easy to do with just the tensioner off, the fan would need to come off and the fan shroud too I reckon.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Is this tensioner usually the cause of a squeak when cold? No squeak when warm Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Mine is doing exactly that, the belt is running about 5 mm off the edge of the tensioner, I have bought a new one and fitting it or having it fitted shortly. BMW i3 Electric Car
probably.
Put a tensioner on my Xmas list |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
Great write up, could i humbly suggest adding part numbers to aid the slower members ( me ) |
its on there a couple of posts down |
Thank you and a classic example of a slower member ( me ) 2015 4.4 AB
| Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147
I checked the tensioner pully today but then saw something worrying.The crankshaft pully seems to run with a wobble |
| All times are GMT |
