Home > Technical (L322) > 4.4TD Cracked Inlet Manifold Questions - Restricted Mode.
Stuart-
My car went into 'Restricted Mode' over the weekend a couple of times.
I took it in the local indy today and they plugged it in, poked around under the bonnet for a while, and diagnosed a likely cracked inlet manifold. Which apparently is a "about a grand" of a job. Big Cry
However, they did say on the 4.4TD there was a manufacturing fault on some of them, and that there was a service bulletin about it. They had heard of LR picking up some of the tab under 'goodwill' if its done at the main stealers "if you chew their ear hard enough" and quote the relevant bulletin number (which they didn't know). They suggested this may be viable even on my 2010 car and full dealer history isnt necessary due to the nature of the failed part.
Does that ring true with anyone? And how to find out the relevant bulletin number please?
Also, if I do have to stump up for it at the indy, does circa £400 for the part and a full days labour at circa £500 sound about right? I've no reason to doubt my indy, but as they say, trust but verify. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Post #492445 15th Oct 2018 7:31pm
Hmm,
Part is £400 on LR direct each side....
Has he checked the small hoses. Linking the manifold to the plenum. These are prone to failure and much more straightforward 👍🏻
If he needs to do the manifolds then it probably is a full day, if it’s just the hoses it’s a couple of hours.
You could have a go via LR though it’s probably an uphill battle. There is nothing that can't be fixed with a hammer😜😜
Post #492446 15th Oct 2018 7:48pm
Baltic Blue
Which side do you think has failed ?
This is a 2nd hand one on eBay at present.
Post #492452 15th Oct 2018 8:09pm
Baltic Blue
I only reported one failed in my Fault Log, but several plenum were reported as cracked., but the most common failure is the 4 short rubber hoses.
Post #492453 15th Oct 2018 8:13pm
Stuart-
It is the drivers side, but with a days fitting involved, I'd not want to chance a used one if there's a known manufacturing fault with them. May end up doing it again in six months otherwise.
Well it was a five minute shufty as I called in unscheduled. He seemed to feel the hoses all looked alright and due to the location of the soot on the engine cover, this signified a manifold. But final clarification would be when it's in to be done I guess. 2017 4.4 SDV8 Autobiography in black
Post #492458 15th Oct 2018 8:58pm
Baltic Blue
This was the only previous manifold crack I found.
http://www.fullfatrr.com/forum/topic44102....d+manifold
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #492461 15th Oct 2018 9:11pm
GraemeS
Australia
The TDV6 inlet manifolds are on their 8th version although they got a year's head start on the 4.4 TDV8 with 2009 production. My son and I recently changed one of his 2009-built 3.0 D4's which took us 2 days although worse engine bay access than the L322 including interference from the EGR valve on the exhaust manifold, which is n/a to the 4.4 TDV8.
Post #492482 16th Oct 2018 12:21am
Stuart-
Looking like the indy and the "about a grand" is the way then. And hope it's something lesser like the hoses or chamber when they start to strip it down.
First available space is next month. I'm a week or so in China between now and then so I'll update when its fixed so Baltic has some data to use for others.
Meanwhile I'll be the bloke turning my engine off at the lights to get the thing out of restricted mode.......... 2017 4.4 SDV8 Autobiography in black
Post #492612 16th Oct 2018 10:16pm
Ive never heard of a 4.4 needing an inlet manifold changing yet! Plenty of 3.6's though...
If yours does need changing then it will need 4 injector fitting kits & pipework as they are a single fit only deal.
I would be checking the 4 inlet rubber pipes first... You can easily check them yourself simply by removing the engine cover (simply just pulls off) and check the four rubber pipes for splits, usually easy to see as will be sooty! Thumbs Up
Post #492618 16th Oct 2018 11:36pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I originally had this diagnosis on 4.4 when it wouldn't pass a pressure test after going into restrictive performance. In the end it was linked to exhaust blow between two sensors and a subsequent miscorrelation. Fault only came up when held at full boost for 30s+ Cheers
James
Post #492635 17th Oct 2018 8:26am
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
The air inlet manifold split on my previous car (4.4 TDV8) whilst in France a couple of years ago. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #492636 17th Oct 2018 8:52am
Baltic Blue
I remember that case Buzz, but I must have mis- recorded it as a split in the plenum rather than the actual manifold.
Sorry.
Post #492637 17th Oct 2018 9:08am
Baltic Blue
Craig,
The one that definitely split is shown in a link a few posts up.
The actual split was around the neck of the “tube” the rubber hoses attach to., on just one of the ports.
Post #492639 17th Oct 2018 10:15am
